Power Beyond question
   / Power Beyond question #1
MR_NC
NW Ohio
2720 TLB
When sizing a valve to be used on the power beyond (add on, not factory).
Should the valve be sized to the total tractor or implement flow?
Thanks in advance!
Best regards,
Sean
   / Power Beyond question #2
implement flow.
   / Power Beyond question #3
Just to be clear, the valve needs to be rated for the entire flow that the implement pump puts out. If your tractor has a 5 GPM for the power steering pump and a 10 GPM pump for all implement use, then the valve needs to be able to flow 10 GPM. If you use a motor spool that takes 8 GPM, you still need a valve that takes the 10 GPM that the implement pump puts out.
You NEVER want to restrict the main flow for any extended length of time. ;)
Thanks for the quick feedback guys!
If I understand correctly (2720 for instance) the implement side is 5GPM, total GPM of tractor is 10.
Valve would be sized to 5GPM in this case correct?
Thanks again!
Sean
   / Power Beyond question #5
Thanks again!
Sean
Correct. Or even a little larger is perfectly OK-just never smaller.
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
TOOL CART (A53843)
TOOL CART (A53843)
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 INTERNATIONAL DURASTAR 4400 (A53843)
2016 INTERNATIONAL...
2008 New Holland B110 MFWD Loader Backhoe (A53473)
2008 New Holland...
