Power Beyond Port
/ Power Beyond Port #1
PRranch
4500 industrial tractor
Does anyone know if a power beyond port exist on a 4500 Industrial tractor. I would like to add a mower attachment to the front end.
/ Power Beyond Port #2
No clue. I would bet you don't have near the hydraulic flow to do it, so it would be moot anyway. Find another way.
/ Power Beyond Port #3
A Ford 4500 industrial has 23gpm on the loader circuit. That might be enough to run a mower. I'd do the calculations first (or look up the mower manufacturer's recommendations) before going down this road too far.
The PB line should be a line from the loader valve to the rear 3pt. Often the 3pt cylinders are in the transmission case, at the very back.
You may want to add a rear remote valve that has a detent and a motor spool. The mower manufacturer should say what sort of valve to use.
/ Power Beyond Port #5
Often the simple answer is backwards to what you are inclined to think.
By a new control valve with a power beyond port.
Install the new control valve BEFORE your other control valves and feed the old valves from the power beyond port on the new valve.
Dave M7040
/ Power Beyond Port #6
My old Ford Industrial tractor with loader had a completely separate hydraulic system for the loader. The pump was in the very front of the tractor, powered by a jack shaft from the crankshaft. The tank was an integral part of the loader.
Jack
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
John Deere 2025R (A64126)
John Deere 2025R...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2003 International 4300 Bucket Truck (A62613)
2003 International...
