Power Beyond Port
/ Power Beyond Port #1
PRranch
4500 industrial tractor
Does anyone know if a power beyond port exist on a 4500 Industrial tractor. I would like to add a mower attachment to the front end.
/ Power Beyond Port #2
No clue. I would bet you don't have near the hydraulic flow to do it, so it would be moot anyway. Find another way.
/ Power Beyond Port #3
A Ford 4500 industrial has 23gpm on the loader circuit. That might be enough to run a mower. I'd do the calculations first (or look up the mower manufacturer's recommendations) before going down this road too far.
The PB line should be a line from the loader valve to the rear 3pt. Often the 3pt cylinders are in the transmission case, at the very back.
You may want to add a rear remote valve that has a detent and a motor spool. The mower manufacturer should say what sort of valve to use.
/ Power Beyond Port #5
Often the simple answer is backwards to what you are inclined to think.
By a new control valve with a power beyond port.
Install the new control valve BEFORE your other control valves and feed the old valves from the power beyond port on the new valve.
Dave M7040
/ Power Beyond Port #6
My old Ford Industrial tractor with loader had a completely separate hydraulic system for the loader. The pump was in the very front of the tractor, powered by a jack shaft from the crankshaft. The tank was an integral part of the loader.
Jack
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A67714)
ALLMAND ECOLED-RIG...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2013 Toyota Sienna Van (A66738)
2013 Toyota Sienna...
2019 FREIGHTLINER CASCADIA 125 DAY CAB (A67714)
2019 FREIGHTLINER...
Club Car Electric Golf Cart (A64912)
Club Car Electric...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
