Power Beyond Port
   / Power Beyond Port #1
PRranch
4500 industrial tractor
Does anyone know if a power beyond port exist on a 4500 Industrial tractor. I would like to add a mower attachment to the front end.
   / Power Beyond Port #2
No clue. I would bet you don't have near the hydraulic flow to do it, so it would be moot anyway. Find another way.
   / Power Beyond Port #3
A Ford 4500 industrial has 23gpm on the loader circuit. That might be enough to run a mower. I'd do the calculations first (or look up the mower manufacturer's recommendations) before going down this road too far.
The PB line should be a line from the loader valve to the rear 3pt. Often the 3pt cylinders are in the transmission case, at the very back.
You may want to add a rear remote valve that has a detent and a motor spool. The mower manufacturer should say what sort of valve to use.
   / Power Beyond Port #5
Often the simple answer is backwards to what you are inclined to think.
By a new control valve with a power beyond port.
Install the new control valve BEFORE your other control valves and feed the old valves from the power beyond port on the new valve.
Dave M7040
   / Power Beyond Port #6
My old Ford Industrial tractor with loader had a completely separate hydraulic system for the loader. The pump was in the very front of the tractor, powered by a jack shaft from the crankshaft. The tank was an integral part of the loader.
Jack
377811 (A48836)
377811 (A48836)
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2020 KENWORTH T680...
Altec Boom Truck Body (A51692)
Altec Boom Truck...
