jgbanshee
- Joined
- Sep 16, 2004
- Messages
- 316
- Location
- PA
- Tractor
- JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
OK, I bought a new hydraulic pump for my Ford 345C and also a new loader valve after breaking both in the process of adding a Bradco bh to this tractor. I replaced the pump and that is buttoned up. Now I am awaiting my new Cross 2-spool valve with power beyond to come in (I got TOP porting for IN/OUT). Since the original loader valve did not have a PB port, the valve split in two when I ran that loader and bh valves in series. Then I broke the hydraulic pump shaft when I hooked the backhoe valve only in the hydraulic circuit. I do not plan on trying anything else until the new valve comes in.
Couple questions.
1. Do I need to prime the gear pump at all before using it since it is new?
2. What should a hydraulic system diagram look like for a backhoe now that I will have PB on the loader valve?
Couple questions.
