Power Beyond Add a Valve
/ Power Beyond Add a Valve #1
lekwyo
Wyoming
4200 HST
I have a JD 4200 and recently was able to get the old Power beyond kit from the dealer who had one laying around in inventory. I would like to use it to access the hydraulics to mount a 2 spool valve. This kit is the old version which basically creates and extra loop in the the line running to the 3PTH. After the kit is installed there is a loop of hose on a QD coupler which keeps the 3PTH circut attached. This line is unhooked so a hydraulic attachment can be plugged in to the circut. When the line is unplugged and this disables the 3PTH as it is taken out of the circut.
My question is, if a 2 spool valve is added with the power beyond lines attached to the valve will the 3PTH work or would it be better to plug the hose to the 3PTH into the power beyond port on the 2 spool valve so the 3PTH will work while using the remotes to run a grapple or top and tilt. Never done a hydraulic project but after reading hours of posts this seems to be the best way to plumb this set up. I am planning on using 2 spool valve 9-7862 from Surplus Center. Any help would be greatly appreciated especially from someone who has a 4200 and has already done this.
Thanks
/ Power Beyond Add a Valve #2
You will not loose the 3PH if you plumb inline with that "loop". The newer PB kits have a extra return to tank line that does bypass the 3PH. You can compare the two in jdparts.
Thanks for the prompt reply kennyd. If the valve is in the loop I assume you would not use the return to tank line that the power beyond kit adds to the transmission just below the transmission fill cap. The return to tank for the 3PTH must be in the transmission. However if the downstream line to the 3PTH was hooked to the power beyond port of the valve this would work as well, wouldn't it?
Thanks for your help.
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
Sioux Mineral Feeders (A66408)
Sioux Mineral...
1996 Aspen FP601 T/A Fracking Pump (A64194)
1996 Aspen FP601...
John Deere X300 Riding Mower (A66408)
John Deere X300...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
