Power Beyond 955 - adding rear remotes
   / Power Beyond 955 - adding rear remotes #1
buildinit
Rusk, Wi
John Deere 955
Well, this will be my attempt to install rear remotes on my John Deere 955. I need help with everything. I don't know how to find the instruction manual, parts list, or valve options. I think I need:
1. Instruction manual for installation
2. Parts list that will work
3. Control valve. My dream is to have one operable on my FEL control stick.
Does anyone have a source for information on how to install the kit?
   / Power Beyond 955 - adding rear remotes #2
The best place to look is your local John Deere dealer. I got the installation manual from the dealers service department. Look on John Deere parts, there should be a parts breakdown of whats required.
   / Power Beyond 955 - adding rear remotes #3
If you're looking for what John Deere offered as a dealer option, JD Parts will yield the individual parts needed to assemble.
If what you want is not a dealer option, you have more work to do. I'm interested to know basically the same thing in that I want valved remotes on my 855. I already have a factory Power Beyond kit installed.
   / Power Beyond 955 - adding rear remotes #4
with power beyond it is really easy. Use the power beyond to to supply your new valves. Brian at FITRITE will set you right up. Or purchase your own valves and install them.
Does anyone know if this is the kit?
Anyone?
   / Power Beyond 955 - adding rear remotes #7
That image you show is only hoses.
The actual power beyond is in,,, or part of a valve.
Different valves produce "power beyond" oil flow in different ways.
All of the valve discussion is seperate from the image you show.
Ok, that makes sense. So, could I install these lines and is that the plug also, then hook up a valve....
   / Power Beyond 955 - adding rear remotes #9
I'm sorry I couldn't get into the account, YES That is the entire Power Beyond Kit !
   / Power Beyond 955 - adding rear remotes #10
The two 90's go into the transaxle , # 15 goes into the side of the Transaxle
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2011 International School Bus (A49461)
2011 International...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
