POST HOLE DIGGER
/ POST HOLE DIGGER #1
CHRYSLER
Hiram,Ohio
2003 JD 4310, FEL, JD brushog ,JD 855 FEL,backhoe, tiller,post hole digger,box blade, 1997Cub 2197 , 1953 Cub , 2004 cub cadet 54" zero turn
I have a 3 point post hole digger that I just tried using today and the auger will not turn, the drive shaft going to the box is turning but the slightest pressure on the auger will stop it although the drive shaft continues to run, worked last year just fine, do not know the name of the unit, most likely the gearbox, what goes wrong with them?
/ POST HOLE DIGGER #2
If you checked for a sheared bolt, then it could be a gearbox issue. Perhaps there's a drive pin fastening one of the bevel gears that has come loose- the friction of the shaft/gear fit is enough to engage the auger, but when there's a bit of pressure on the auger, the shaft slips? Good luck.
/ POST HOLE DIGGER #3
Is the unit shear bolt or slip clutch style?
Sent from my Milestone X2 using TractorByNet
/ POST HOLE DIGGER
from what i know about it its a shear bolt style
Towable Pump (A64553)
generator trailer (A61569)
generator trailer...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
