Post hole digger-BX24
   / Post hole digger-BX24 #11
I have a land pride PD10 for ny BX it is made specifically for sub cuts. It works fine in soft ground but to get it to dig in the hard stuff i had to buy carbide tips. I still have to but weight on it to get it to dig in hard clay and it will not dig clitche at all.
   / Post hole digger-BX24 #12
   / Post hole digger-BX24 #13
I've dug about 30 holes in medium hard material with the digger in the picture without any problems. It is a Rankin 600 which is a Shaver 601.
   / Post hole digger-BX24 #14
   / Post hole digger-BX24 #15
The key is making sure you get a PHD that will work with your BX.
MY Rhino HPHD won't. It would hardly fit my B2910.
Without question the BX will power a PHD IF...IF...you get one that fits the limited size cat 1 3PH.
Fact of life...the BX 3PH is a bit smaller than standard. OR...all the other Cat 1 3PHs are larger than standard... /forums/images/graemlins/shocked.gif
   / Post hole digger-BX24 #16
Thank you for all the information. Kurt
   / Post hole digger-BX24 #19
Ultrarunner has said that the Land Pride unit (with downpressure) on his BX23 digs through caliche and serpantine with no difficulty.
   / Post hole digger-BX24 #20
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
SKID STEER QUICK...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2001 JOHN DEERE 8410T TRACTOR (A51243)
2001 JOHN DEERE...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
