Post hole digger-BX24
   / Post hole digger-BX24 #11
I have a land pride PD10 for ny BX it is made specifically for sub cuts. It works fine in soft ground but to get it to dig in the hard stuff i had to buy carbide tips. I still have to but weight on it to get it to dig in hard clay and it will not dig clitche at all.
   / Post hole digger-BX24 #12
   / Post hole digger-BX24 #13
I've dug about 30 holes in medium hard material with the digger in the picture without any problems. It is a Rankin 600 which is a Shaver 601.
   / Post hole digger-BX24 #14
   / Post hole digger-BX24 #15
The key is making sure you get a PHD that will work with your BX.
MY Rhino HPHD won't. It would hardly fit my B2910.
Without question the BX will power a PHD IF...IF...you get one that fits the limited size cat 1 3PH.
Fact of life...the BX 3PH is a bit smaller than standard. OR...all the other Cat 1 3PHs are larger than standard... /forums/images/graemlins/shocked.gif
   / Post hole digger-BX24 #16
Thank you for all the information. Kurt
   / Post hole digger-BX24 #19
Ultrarunner has said that the Land Pride unit (with downpressure) on his BX23 digs through caliche and serpantine with no difficulty.
   / Post hole digger-BX24 #20
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
