Post hole digger-BX24
   / Post hole digger-BX24 #11
I have a land pride PD10 for ny BX it is made specifically for sub cuts. It works fine in soft ground but to get it to dig in the hard stuff i had to buy carbide tips. I still have to but weight on it to get it to dig in hard clay and it will not dig clitche at all.
   / Post hole digger-BX24 #12
   / Post hole digger-BX24 #13
I've dug about 30 holes in medium hard material with the digger in the picture without any problems. It is a Rankin 600 which is a Shaver 601.
   / Post hole digger-BX24 #14
   / Post hole digger-BX24 #15
The key is making sure you get a PHD that will work with your BX.
MY Rhino HPHD won't. It would hardly fit my B2910.
Without question the BX will power a PHD IF...IF...you get one that fits the limited size cat 1 3PH.
Fact of life...the BX 3PH is a bit smaller than standard. OR...all the other Cat 1 3PHs are larger than standard... /forums/images/graemlins/shocked.gif
   / Post hole digger-BX24 #16
Thank you for all the information. Kurt
   / Post hole digger-BX24 #19
Ultrarunner has said that the Land Pride unit (with downpressure) on his BX23 digs through caliche and serpantine with no difficulty.
   / Post hole digger-BX24 #20
John Deere 6115M (A50120)
John Deere 6115M...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
David Bradley Manure Spreader (A50515)
David Bradley...
(INOP) NEW HOLLAND TV6070 TRACTOR (A51243)
(INOP) NEW HOLLAND...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
