Post driver for a class 1 3 point
/ Post driver for a class 1 3 point #1
Irap
TYM/T454
Does anyone have information on what brand of a post-driver that is good but doesn’t cost a arm and a leg.
/ Post driver for a class 1 3 point #2
Shaver makes a nice one but new its $$$ Maybe a farm auction or FB market place.....
/ Post driver for a class 1 3 point #3
Have you considered looking for a used one..?? 10 years ago, I bought a good, barely used, fully hydraulic Shaver HD-8, for 1/3 the price of a new one on ebay. It was a 3 hour one way drive to get it, but saving $1600.00, it was worth the trip for me. Plumbed it up to my old Ford 2000, anddrove 350 posts, with the only issue. broke a return spring after about 75 posts. Called local dealers that handled parts,and it was going to be 7-10 days before they could get one in. Checked online, and found Kencove fence supply, and they sold direct replacement aftermarket springs, for about 2/3 the price at local dealers, w/free shipping, and had them in 3 days. Ordered 2 just in case, but the first one I put on lasted the rest of the posts I drove. Kencove Farm Fence Supplies - Kencove
I would suggest which ever one you choose, to get a full hydraulic tilt model. Worth the extra money, to tilt with hydraulics, rather that hand screw adjustments.
Look for one's from private individuals on Craigslist FB Marketplace, ebay, etc.
/ Post driver for a class 1 3 point #4
Dad bought a used Shaver HD8 in the mid 1970's. Apart from some safety items that have been bolted on new units over time and a valve manufacturer change it was identical to one you would buy today.
I have looked at them new.
I have been looking for used ones after I seen the cost of the new ones. I will start looking on eBay and other sites farther away from where I am. Thanks for the information.
/ Post driver for a class 1 3 point #7
/ Post driver for a class 1 3 point #8
I don't like shavers at all. Google blackcat post pounder. I can recommend them. They can be found used
/ Post driver for a class 1 3 point #9
Use right or left handed or one handed.. but suggest both.
Definitely a two handed model but use as you wish.
:laughing::laughing:
Both under a 100 bucks.
/ Post driver for a class 1 3 point #10
Agreed. Mine is from the early 1970's, it uses the same parts as ones built today. I wish mine had some of the creature comfort safety items the new ones do but I haven't felt like breaking down and buying those parts to put on mine either.
To the original poster, your tractor should handle the Shaver HD-8 just fine. I have a Mahindra 2638 and while I haven't got my Shaver hooked up to it yet I see no reason that it will not work, I just need to find a pipe fitting that will thread into the hydraulic fill so I can direct plumb the return into it. I've got a shop I need to take the tractor to that should either have the correct threaded part or can make it.
/ Post driver for a class 1 3 point #11
I have a Danhuser T3 driver that mounts on the tractor loader and runs off of the 3rd function valve. We use it to drive 2 7/8" oil pipe down 4 to 6' into hard clay. Cost about 2K new. It can take five or so minutes to drive a 10' piece of pipe down so I have about 4 and a half foot sticking up, but they do not move after that. The bigger drivers are faster, but I am not going to do enough fence work to justify one.
/ Post driver for a class 1 3 point #12
I've got a lot of fencing going up shortly and have looked at the T3 driver.
How much adjusting do you have to do with the tractor as the post goes in? My concern is the arc of the loader as it comes down.
Thanks for any insight you can provide.
/ Post driver for a class 1 3 point #13
First two feet you have to may attention to the angle but after that just put the tractor in neutral and it will stay straight. One day I am going to make a rail guide for it to run on to make it easier to lock the posts in so I can run it by myself, otherwise you have to have a second person to hold the post up to get it started.
/ Post driver for a class 1 3 point #14
Thanks again, I may have to look at these again
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Werk Weld (WW) Portable Creep Feeder (A66408)
Werk Weld (WW)...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
