Position Control?
/ Position Control? #1
RhallVA
VA
Still not sure what Position Control does for me or what I might hate about not having it. I am thinking of getting a Kubota B7500 which does not have position control. How will that effect me in the use of a rear blade or rear mower? How about a posthole digger? How would doing these things be better or easier with position control?
Thanks!
Roy (clueless, be needing to buy a tractor w/o screwing up)
/ Position Control? #2
Roy
Here is a link that has some good information about position control. <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=buykubota&Number=48302&page=&view=&sb=&o=&vc=1#Post48302>Click Here</A>. By doing a search for "Position Control" you will find several other threads that discuss this subject.
/ Position Control? #3
Roy,
I bought the B7500 w/o position control. It's true what they say, you don't know what you missed if you've never had it.
PC allows you to set the 3PH at a particular height where it won't drop below (3PH will still be able to "float up" on most tractors).
This can be useful for 3PH attachments where working height is important; mowers, blades, plows. I don't think it would make a whit of difference for a post hole digger, but I've never used one, so I will say nothing on that score.
That said, a good tractor operator should be able to figure out how to do stuff even without it. Especially since I find that I can. /w3tcompact/icons/smile.gif
/ Position Control? #4
If you have never had position control, you may never miss it. My Yanmar doesn't have position control and I use it frequently with both a box blade and rotary cutter. You will probably never miss it with the post hole digger. However, my Dad's Mitsubishi MT160D that I have operated for years has position control and there are times that I wish my tractor had it, especially when mowing.
/ Position Control? #5
Roy
I looked at the B7500 at first and bought a B2400 because it had position control. I felt that the 7500 could do what I needed, but I thought the PC would be helpful. As it turns out, I am glad I spent the extra $. The ability to raise the 3ph and then return to a selected level has been a big help for a novice. I find there are times I need to change the height of what I am doing and I can just look at the PC lever and corresponding number and I am at the level I want to be at. Having said all that, I am sure I could have learned as Glue Guy and others have to do without it. I think my productive learning time has been shortened by having it. You may also find the little extra size with a B2410 is also helpful. In short, if the extra $ do not deter you, I would go for it.
Billy
/ Position Control? #6
I would prefer the B2410 because I think it is a more refined design than the B7500, however, I would not buy it just for the position control.
I had an L175 without PC and I now have a L3010 with PC. I think the L175 actually allowed for smoother adjustments to the 3PH level. I just don't see that much advantage to the PC. Either way you will have alot of fun.
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2019 CAT 259D (A60462)
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
