portable winch
/ portable winch #1
cmkh3
Kitsap County, Washington
John Deere 322
Has anyone mounted a portable winch on a Mahindra 28 xl hydro? I would like to have one that I can hang on the front or back as needed if it gets stuck in a "hairy" situation. When doing land cleanup on our 2.5 acre hill side property I tend to do that.
Thanks
Chris
/ portable winch #2
I'll be installing a winch on mine also, in the near future.
My guess would be to install it somewhere at the rear,
simply because you usually drive forward into a "hairy" situation
and will need to pull yourself "back" out.
Also, I would think, the lower it is, the better,
so somewhere at the back and as low as possible is my thought.
/ portable winch #3
Add a 2" reciever to the front and one at the rear. Mount the winch to a plate that can be moved to either location on your tractor oryour truck...
/ portable winch #4
I made a winch that was three point mounted,
/ portable winch #5
Mine is lower capacity, but useful to pull my windmill pump. It als works good for pulling bushes in landscape. It fits in a receiver welded to the bucket.
/ portable winch #7
I have a this
mounting on this
Winch works great, also have front and back receiver on my truck. It does come in quite handy.
/ portable winch #8
I have the same winch.
Welded a receiver hitch onto the front weight.
Used it many times, back when I had the tractor.
Sold the tractor, kept the winch. :D
/ portable winch #9
/ portable winch #10
I also did a very close copy on my MT180D at the rear. Very useful to drag trees out.
Yep, now I can do the same with my V417 :thumbsup:
And on the front in this three point receiver hitch if I need it there.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
DEERE 544K GP Bucket (A68134)
DEERE 544K GP...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2021 WEILER K560...
2017 Ford F-150 Crew Cab Pickup Truck (A68183)
2017 Ford F-150...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
