portable winch
/ portable winch #1
cmkh3
Kitsap County, Washington
John Deere 322
Has anyone mounted a portable winch on a Mahindra 28 xl hydro? I would like to have one that I can hang on the front or back as needed if it gets stuck in a "hairy" situation. When doing land cleanup on our 2.5 acre hill side property I tend to do that.
Thanks
Chris
/ portable winch #2
I'll be installing a winch on mine also, in the near future.
My guess would be to install it somewhere at the rear,
simply because you usually drive forward into a "hairy" situation
and will need to pull yourself "back" out.
Also, I would think, the lower it is, the better,
so somewhere at the back and as low as possible is my thought.
/ portable winch #3
Add a 2" reciever to the front and one at the rear. Mount the winch to a plate that can be moved to either location on your tractor oryour truck...
/ portable winch #4
I made a winch that was three point mounted,
/ portable winch #5
Mine is lower capacity, but useful to pull my windmill pump. It als works good for pulling bushes in landscape. It fits in a receiver welded to the bucket.
/ portable winch #7
I have a this
mounting on this
Winch works great, also have front and back receiver on my truck. It does come in quite handy.
/ portable winch #8
I have the same winch.
Welded a receiver hitch onto the front weight.
Used it many times, back when I had the tractor.
Sold the tractor, kept the winch. :D
/ portable winch #9
/ portable winch #10
I also did a very close copy on my MT180D at the rear. Very useful to drag trees out.
Yep, now I can do the same with my V417 :thumbsup:
And on the front in this three point receiver hitch if I need it there.
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A67714)
2006 W-W TRAILER...
330 GAL WATER TANK (A68842)
330 GAL WATER TANK...
KUBOTA MOTOR (INOPERABLE) (A68842)
KUBOTA MOTOR...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
x (A68191)
x (A68191)
