Portable lumber mill
/ Portable lumber mill #1
oakiemac
Has anyone had in experience with the Portable lumber mill that hooks up to your chainsaw. Northern tool sells one that is called the Alaska MK 111. I'm looking to cut up some cherry logs into rough boards and was wondering if this mill is worth the $164.00 bucks that they are asking. Right now I can't afford the larger portable mills that sell for several thousands. Any input would be appreciated.
/ Portable lumber mill #2
They work, but so do you! Add the cost of a couple of ripping chains, as the crosscut chains don't rip so well. And the kerf is as wide as your chain, so you lose a lot of wood. After trying a friend's, I hired a fellow with a Woodmiser to cut up my hardwood logs. Cost me $0.10 per bf and was worth every cent!
Pete
/ Portable lumber mill #3
I've got one that was given to me. It was worth every penny I paid for it.
If I really needed to rip lumber with a chainsaw I'd build better.
The waste in wood chips amounts to 1 board every 4 you cut on 1" boards.
If you can hire a mill, do so.
/ Portable lumber mill #4
There is a forestry site with members that have portable mills, and if you are interested in finding someone in your area, you might check it out (as well as your chainsaw mill question).
http://www.forestryforum.com/
2014 FREIGHTLINER M2 FLATBED (A67148)
2014 FREIGHTLINER...
8ft Fork Extensions (A64553)
8ft Fork...
2026 Loadtrail 20ft. 7 Ton T/A Deck Over Flatbed Equipment Trailer (A64194)
2026 Loadtrail...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
