Portable bandsaw mills
   / Portable bandsaw mills #1
dlabrie
Campton, NH
Kubota B2910
I have about 8-12 acres of spruce, pine, oak and maple. I was going to sell it off to a logger, but then I was wondering if I could buy a portable bandsaw mill and make enough $ to pay for it and have lumber for myself. Does anyone have one? What is your experience? Is one brand better than another? Will a low-end model be adequate?
Thanks,
   / Portable bandsaw mills #3
I'm a closet sawyer want a be that sometimes gets the same thoughts you are having. I visit www.woodweb.com and read what the people on the wood sawing forum have to say. Ask them and you will get 100 answers....from some pretty savey folks ...like Arkansawyer and Bibbyman..... always entertaining.
sassafraspete
   / Portable bandsaw mills #4
I have a Wood-Mizer LT30 that I have had for about 12 years. Good little saw and good company support. The thing about small mills is they all will do a good job, but they have their limitations. The small mills will be slow on production sawing and are more labor intensive, you will have to position and turn the log manually. The larger mills are faster, have larger motors and log handling capabilities. On a small mill you will be doing good to cut 1000 board feet in a day and you will be tired when the day is done.
You can get by without an off loader (helper) but this will slow you down dramatically. A truck or trailer and a tractor with a loader will be very helpful. Green logs are heavy and beyond muscling so you will need cant hooks, winches, chains or steel cable to mention a few things.
If you skid your logs you will need to clean them before cutting. Skidding gets mud and stones in the bark and these will dull your blades very quickly. Cleaning the log is done by pressure washing or de barking the log. De barking can be done by hand with a bark spud, shovel or hand axe. I have a de barker that fits on the end of a chain saw, it is basically a jointer head driven by the saw chain. The newer, larger, Wood- Mizers have a de barker on the mill that cleans the log in front of the blade.
Cutting your own wood is satisfying, but hard work. When looking at mills look for company support and blade service. Will you sharpen yourself, if so, you have to buy the equipment to do so or you can go with a sharpening service. I would recomend one of the older established companies that will still be there 10 years down the road. Good luck!
   / Portable bandsaw mills #5
Forestry Forum
All you ever wanted to know about wood, sawing, logging, and some great stories too... Kinda like here, only with sawmills instead of tractors...
Thanks for the info. Those sites mentioned have a wealth of information! I am learning how much I don't know about sawing wood!
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
