Porch Storage Area
/ Porch Storage Area #1
timswi
Super Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
Got a question for you guys...I have a 8'x50' non-climate controlled storage area under my concrete front porch (no roof, yet). Problem is, the steel decking likes to sweat. I have a dehumidifier running all year and I spray foamed the corrigated spaces against the block to prevent the chimney effect, which helped a ton.
Is there some type of insulation that can be put on the steel to calm the temp variances? I don't want to use standard foam board --I don't believe that stuff is supposed to be left exposed in a residential structure, or am I wrong?
Any suggestions beyond heating and cooling the space?
Any suggestions are more than I have. Thx
/ Porch Storage Area #2
The sweat is caused by humid warm air hitting the cool metal. Warmer because of the earth's warming effect. I have the same problem inside inclosed metal buildings with dirt floor. Open front buildings don't sweat near as much but of course rain blow's in.
/ Porch Storage Area #3
Spray the steel decking with closed cell foam, then cover with what ever you want. Put a vapor barrier down on the floor. Heavy plastic sheeting would work. Then cover with plywood or OSB.
I could try that although putting panels up would be preferable for me...This room has a concrete floor with access via my game room. Completely enclosed except the entrance door. Electric, freezers etc live in there.
/ Porch Storage Area #5
Huber zip-r in r9 would probably be enough insulation and you can place the wood on the inside. I don't know if this product is technically rated for use in such an application. You would want to vent under the steel roof to the outside somehow though.
Actually it's not a steel roof, it's the steel decking for the concrete porch above it
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
John Deere Starfire 6000 (A64126)
John Deere...
Spirit Electric Tricycle (A64127)
Spirit Electric...
2022 John Deere 5055E (A64126)
2022 John Deere...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
