Popping out bushes?
   / Popping out bushes? #11
I did some mature boxwoods a few years back and it was a miserable job. When mature their roots are fibrous and intertwined. if you can yank them with a chain then great. Mine didn't come out without a lot of struggle. Wound up digging the roots out with a strong loader.
   / Popping out bushes? #12
The soil may have enough moisture in it this time of year to make it easier to pull them out than in the dry of summer, but it may be rough on the lawn.
   / Popping out bushes? #13
Have you considered cutting them down and then stump grinding? I did that with my 200' long 6' tall overgrown hedge. Rented a walk behind stump grinder (Stump Grinder Walk-Behind | Sunbelt Rentals) to chew it all up. Planted new right after grinding. The chips were mixed with the soil. So far, everything is happy.
That will be plan B. If the Workmaster 40 doesn't have enough rear end to get the job done I'll just cut 'em down and grind on them later this spring.
   / Popping out bushes? #15
It wouldn't hurt to get a couple old plastic 1 gallon buckets, drill a 3/8 hole about 1/2 in from the bottom.
Place the bucket with the hole on the upper side and pour a gallon or 2 of water the hole will let it soak in, move the bucket and water a 2nd and 3rd bush when you tackle the 1st one, depending on soil type it might help.
   / Popping out bushes? #16
Good luck... boxwood roots are far tougher than you think. I ripped a 3 point top hitch out of a tractor (6 bolts), trying to pull up a small 3x3 boxwood. Granted it was a cheap Chinese tractor...
Lots of axe work, cutting roots and hand digging deep down and was able to yank it out with a Dodge Ram 2500, pulling hard. These boxwoods were very, very old.
   / Popping out bushes? #17
I'd suggest pulling them out with a chain attached to the drawbar so you are pulling from the lowest point available. Smokeydog posted this grabber he made from 2" pipe. I made one and will attest to it being able to grab brush without slipping.
I just made one of those and tried it out. Slick. The thing works.
Now I regret that part of the yard is too muddy to put my tractor on or I'd do more ripping out little trees.
   / Popping out bushes? #18
I second that info... My experience was removing about 10 of mature box woods at work one day. I had access to one of our 5,000# fork lifts. Ha! That sounded quick and easy, but it proved to be far from it.
My imagination was to pull the forks close to each other and simply 'pluck' them out. Nah - it proved to be a lot more work than anyone would have thought. Possible, but not quick and easy by a long shot. I'm guessing that there's some root cutting in fishheadbob's future.
   / Popping out bushes? #19
Found a photo of removing the "massive" boxwood stumps... and right before the bolts stripped out of the back of the Nortac dozer!
   / Popping out bushes? #20
I've never seen anyone put a hoe on a dozer. Pretty slick!!
2008 International 7500 Altec A77-TE93 92ft. Material Handling T/A Bucket Truck (A55973)
2008 International...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
7ft Workbench (A57454)
Dewalt 14" Chop Saw (A59076)
Dewalt 14" Chop...
2012 MACK CHU613 (A58214)
2012 MACK CHU613...
1993 UTILITY TRAILER MANUFACTURER 45 FLATBED T/A TRAILER (A58214)
1993 UTILITY...
