Snow pookie tractor
   / pookie tractor #1
cas1954
farm pro 2425
i 'm having an issue with my Farm pro just started last two snowfalls when plowing. The tractor seem to loose drive when the accellerator is increased.it drives when at low RPM's . The tractor has no power to drive itself HELP it's been extremely cold and the tractor is outside
   / pookie tractor #3
Does your Farm pro have a gear or hydrostatic transmission ?
   / pookie tractor #4
Is fuel gelling? Have you checked for good fuel flow from tank to inj pump?
   / pookie tractor #5
If HST what range are you using,are the fluids warm.
   / pookie tractor
it is a gear using righ range and 1st gear
   / pookie tractor
the engine is runningfine just that it seems as if the clutch slips when engine is reved up
   / pookie tractor #8
Clutch iced up? Most of those tractors have a bellhousing drain in case you got water in there,.
   / pookie tractor #9
If'n the tractor slows down with the engine revs staying the same the clutch may be slipping. Might be an adjustment?? or needs a new clutch. ?
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
(2) Military Front & Rear Differential (A50121)
(2) Military Front...
1013 (A51573)
1013 (A51573)
2015 Kawasaki Mule 4x4 Utility Cart (A50322)
2015 Kawasaki Mule...
2018 Genie 2632 26ft Electric Scissor Lift (A50322)
2018 Genie 2632...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
