pond
/ pond #1
handgun357
Howe, IN
1955 Ford 860... Farmall H 1946
Does anyone have any first-hand knowledge of lining a new pond with sodium bentonite ?
How - soil type - time of year - animal issues - longevity - pitfalls
Does anyone know where to get some in north central-northeast Indiana?
Thanks in advance.
/ pond #3
Cost prohibitive for me. Also suggested to mix with dirt before spreading .... i don't know how to mix a dump truck full of anything - lol.
I did test a small area, about 15' x 15', and it works. If you have cattle on your pond, they can punch holes with their hooves.
I've decided to just go with good pond quality clay and put in at least a 6" layer.
I had a neighbor who said he had a pond that wouldn't hold water, so while it was dry, he spread a pretty good layer of old poor quality hay all over it, then put a big round bale of good hay in the middle and the cattle tromped it real good and the next year it filled up, and never dried up again.
When you say "new Pond", is this a pond that is just recently dug? or one you are planning on digging?
IF you have poor quality soil, I'd rethink the pond. IF quality is good, you dont need it.
I am building a pond. Everyone I talk to says the clay / bentonite doesn't work too well. I am putting in a liner. Cost is around fifty cents a square foot so not cheap but it supposedly works really well.
Bentonite will improve the quality of the soil if the clay that is there is just fair. It needs to be mixed in with the clay and the amount you use varies by the quality of the soil. It can be hit or miss, and it can be a total waste of time. It can also solve all your problems. You just don't know for sure because even if you get the right amount, mixing it with a disk and packing it down might not be right. The other issue is that it might not be your clay, it might be there is sand or gravel just under the soil that is causing a leak. There might be a spring that is draining the water out of the pond. Springs can fill a pond, and they can drain a pond when the table water is low. Then there is the quality of the dam. How was it compacted. Most just get by with running a dozer over it. But a dozer is the very worse tool for compacting soil. The tracks are designed to float over the ground and have the lowest possible weight per square foot possible. Just piling dirt up for a dam on existing dirt leaves a layer of two different types of soils for the water to pass through, so digging a core trench helps with that. The core trench also locks the dam in place so it doesn't slide away or move when the pond fills up with water pushing it out. The size and weight of the dam has to be enough to hold the water back. The core trench locks the dam in place.
Liners work, but they can be damaged pretty easily. They are a big upfront expense that seem to last a certain length of time, then fail. How much you spend usually reflects the quality of the liner. How thick it is and what it's treated with to prevent breakdown over time.
Pond Boss has lots of information, but it's hard to find anything usefull and the core group of posters over there just turn everything into a joke towards each other. Most of them hired somebody else to dig their pond, or they bought a place with an existing pond. I've given up going there for information.
Eddie
As well as sealing ponds, sodium bentonite is also used for electrical grounding. It is added to the soil around earthing rods to reduce the ground resistance. When I looked at pricing (in the UK), the material sold for electrical use was considerably cheaper than that sold for ponds.
Not sure if the specification on bentonite for ponds is the same as for electrical grounding. Anyone know, or tried some out ?
I'm told that any well driller will have a source of bentonite..or anyone who does sewage ponds.
/ pond
thanks very much for the info..........
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
Shell Gas Pumps Yard Art (A64557)
Shell Gas Pumps...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
BESTWAY AG 1600 GALLON NURSE TANK (A64278)
BESTWAY AG 1600...
