Pond Bridge
/ Pond Bridge
I am sure a railing would be a nice touch. My only thought is that with the bridge 5' wide will a railing get in the way if you buy any wider implements?
MarkV
Honestly I don't have any plans or can I see that I will need larger implements in the future. the b7510 is quite large enough for my property.
/ Pond Bridge #22
Since you are going to fab the railings, make one side E Z to remove [or both sides] if extra clearance is needed...
/ Pond Bridge #23
If you have a 4' implement and it gets to swinging from side to side as you cross the bridge, you could get some damage to the railings. If you have a 5' wide bridge and a 4' implement, that's only 6" of clearance on each side.
/ Pond Bridge #24
How soft does that ground get in the wet season? are you sure the legs of your bridge will not sink into the ground? Looks as if where the legs are it could stay wet and soft and your legs from the bridge will eventually start sinking into the ground and worse yet one side faster than the other.
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2012 FRAC TANK 500BBL WHEELED (A65643)
2012 FRAC TANK...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2022 DODGE RAM 2500 (A65643)
2022 DODGE RAM...
