Pole building question
   / Pole building question #1
Newtocvt
Bronze Member
Menomonie,Wisconsin
New holland 54d
I am thinking of building a pole building for general storage. Mostly for implements I don't want to leave out all winter. I don't need an insulated or heated building and was thinking about just gravel floor. Size wise I was thinking about 24x32 with one 9 foot garage door and a service door. No windows. The area I am thinking about slopes 2-3 feet over the 32' span. My question is can I set the post before the site is leveled and graded. My theory is I can set the post 4 feet deep with my post hole digger than the back full and gravel would essentially make the 6-7 feet deep. Any thoughts?
   / Pole building question #2
I think you will find it to be more than a major nuisance to be grading around posts already set.
   / Pole building question #3
That. Even if it means you build a retaining wall.
Jim
   / Pole building question #4
And do have a bldg code? Around here you'd need to have a footing under each post, inspected before backfill. Not a bad idea, even for storage.
Jim
No building code here. I already checked with the township only thing they care about is the road setbacks. It sounds like I should just get the area prepared first.
   / Pole building question #7
Prior proper preparation prevents poor performance.
   / Pole building question #8
Couple of things we had a high lift level our pad and really compact it so it shouldn't settle. Second if you do metal I highly recommend insulating the roof or it is going to sweat and drop water on your implements, the bumble wrap to do my 30x40 was an extra 300$ well worth it. I would level, compact then set your posts
   / Pole building question #9
I had a couple feet of fill added for my pole shed and had a driveable vibratory roller go aver it a couple times. When I had to dig for some plumbing pipes I had a difficult time shoveling and picking through it. That is a good thing and money well spent.
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A53472)
2018 Rock Solid...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
378499 (A51573)
378499 (A51573)
