pole barn with loft
   / pole barn with loft #3
Welcome toTractorByNet and greetings from Tennessee.
   / pole barn with loft #4
:welcome: to TBN from Ohio. Am building a barn tomorrow.
   / pole barn with loft #5
I wish I had built taller walls with a loft in mind. When friend had his barn built the Salesman talked him into getting "loft prep" It eliminated a truss and used heavier roof purlins.
I did end up building a loft, but have a truss to deal with.
   / pole barn with loft #7
You could use an attic truss for the end that will have the loft. You can get them from a truss company, or you can contact a truss company with your dimensions. They will give you a diagram with their quote, and you could build your own from their dimensions.
   / pole barn with loft #8
NO, no, no, no no.....Don't ever attempt to build any sort of truss on your own by pilfering a prefabricated truss design. Besides being unethical, you will not be able to purchase the grades of lumber required, and you will have no access to, or ability to properly press in the steel connector plates. And attempting to use osb or plywood "gussets" to replace the connector plates is not going to provide adequate connections.
   / pole barn with loft #9
There are numerous options available for getting a loft in a pole building. More often than not, building owners do not plan adequate height to properly be able to fully utilize the loft. My best recommendation is to discuss your needs with a qualified pole building kit package provider, who can do engineered designs, provide the plans, materials and installation instructions to properly construct. In the long run, it is well worth every penny.
Read more at:
Loft Aspirations Part I: Attics and Lofts
Loft Aspirations Part II: Bonus Room
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2019 FORD F-250 XL SUPER DUTY SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
