Pole Barn - Why not use center post?
   / Pole Barn - Why not use center post?
Bearcreek,
I look forward to seeing the truss design. From my research into trusses I think a 28' clear span truss with 1' overhang will take advantage of 16' lumber with only one joint on the bottom chord and no joints on the top chord.
Bobrip,
I am certainly leaning towards the trusses. Would really like to try and build them myself. I could see three rows being productive. I am sure I will be glad that everyone has advised me of going that direction.
Has anybody used the standard pressure treated 2x6's laminated for post? Adding the asphalt enough protection?
I am sure everyone has seen these truss designs by Midwest. I don't understand why it is saying both 4/12 and 5/12 use a 16' top chord?
Any problems with this design using 2x4x16's? 24" on center?
  • truss_28.pdf
   / Pole Barn - Why not use center post? #43
Your talking about 10' bays ... are you planning the rafters 10 O.C. ? Use a double plate and you could go with 2x8 rafters 5' O.C. and use 2x4 purlins
2x8 rafters to span 30 feet?
Don't even consider it, you are not qualified to build a truss.
lol...why is that?
No. I was talking about running from outside post to center post -15'. Thanks
   / Pole Barn - Why not use center post? #46
   / Pole Barn - Why not use center post? #47
Well building a truss is not that difficult ... in fact I think even you could do it ... follow a drawing .. available online ... use the first one for a pattern and build the rest.
   / Pole Barn - Why not use center post? #48
4/12 pitch the top chord is 15'10" or use a 16' 2x8 and BANG your done !!
   / Pole Barn - Why not use center post? #49
I'm sorry ... you will have to calculate the webbing and layout the plywood gussetts ...
   / Pole Barn - Why not use center post? #50
4/12 takes 15'10" and a 5/12 takes 16'3 ... they may be holding the 5/12 in on the bottom web ... on each side, I doubt it ...but they maybe doing it to save from going to 18' lumber
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
iDrive TDS-2010H...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
Ford 8510 (A53317)
Ford 8510 (A53317)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
