Pole barn...anchor posts?
/ Pole barn...anchor posts? #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
I'm building a 30" x 36" pole barn style garage. There are 26 posts in total. My question...do I need to anchor the posts to their concrete pads? The posts are all just sitting on their respective pads (to minimize rot) and will have, on average, about 18" of fill. I'm a little concerned about "up lift" from severe weather conditions. The anchors will cost about $600 for materials alone. Money well spent, or just wasted?
/ Pole barn...anchor posts? #2
A few years ago I built my pole constructed shop using pressure treated 4X6 posts. We set the posts on a 6" concrete pad in the bottom of a 42" hole. To resist "heaving" out of the hole we nailed (2) 2"x6"x6" pressure treated "cleats" on opposite sides of each post; bottom of cleat was flush with the bottom of the post. I've had no problems with any vertical movement of the posts. We can see temperatures below zero here in January/February. Cleats are required by our county building inspector in all pole building construction. No anchors were required or used.
-Len
/ Pole barn...anchor posts? #3
I built a 24X48 pole barn for a neighbor about 10 years ago, set the posts about 36" deep and there's been no problem with heaving.
All I did was punch 12" wide holes and put rocks in the bottom for drainage -- no concrete cookie -- and it's doing fine -- but we also poured some concrete around the posts and have 24" eaves to help keep the area at the bottom of the walls dry.
/ Pole barn...anchor posts? #4
At 18” deep are you deep enough to be below the local frost line? Around here we would normally go about 48” and the friction of the ground against the pole prevents up lift do to high wind.
MarkV
/ Pole barn...anchor posts? #5
I poured mine 48" deep and 6" above the grade, put 2 pieces of flat iron into the wet cement with 2 holes drilled in each. I mounted the polls on the cement with a sheet of aluminum below to stop wicking any moisture and lag screwed the polls in. My neighbor asked me if I was building it to last 3 centuries.
/ Pole barn...anchor posts? #6
-Len
That is exactly what I did.
/ Pole barn...anchor posts? #7
I'm in the eastern panhandle of WV and built a 32' x 40' pole barn about 7 years ago. I went 54" deep on my holes - put in 6" gravel and set my poles on top of that then filled holes with concrete. (I know - there's the concrete or earth backfill debate).
The reasearch I did in advance of building advised:
1) poles should be set below the frost line in your area (30" here in Jefferson County WV)
2) pole depth is determined by the size of the building sides, the roof overhang and the diameter of the poles. Pole depth primarily resists uplift generated from wind on the sides of the building and under the eaves. Pole resistance is a function of the surface area of the pole in contact with the backfill. There are books on pole buildings (I got mine from Amazon.dom) that have reference tables for detemining how deep you should put your poles with adjustments if you use cleats or anchors. I'm pretty sure from what I remember of the tables that 18" isn't deep enough even with anchors.
Amazon.com: Practical Pole Building Construction: With Plans for Barns, Cabins, & Outbuildings: Books: Leigh Seddon
Amazon.com: Building Small Barns, Sheds & Shelters: Books: Monte Burch
Amazon.com: Monte Burch's Pole Building Projects: Over 25 Low-Cost Plans: Books: Monte Burch
Hope this helps - be sure to post pictures of your buinding progress.
WVBill
The frost depth where I live is 24". We dug down about 30" in most areas. There are 26 posts in my 30 x 36 building. On average, the posts are 5 feet apart. On closer inspection, the 18" number I mentioned above is only for a few holes with extra concrete. I will measure each hole tomorrow for my own curiosity.
Regarding the hold down brackets, they are not readily available with the proper amount of galvanization for treated lumber. They now have to be special ordered with a 4 to 6 week wait. I did find 11 brackets that were old inventory at the lumber yard with the correct amount of galvanization. I installed those around the perimeter. Regarding the use of a treated lumber sleeve, that isn't easy to accomplish ether. Most commonly available 2x lumber only has a .10 treatment. Lumber placed below grade should have a .31 treatment. This is a special order and the lumber yard will not order the small quantity I need.
Most pole barns are build with poles on 8' center. With no openings, that would be 16 posts around the perimeter for my building (132 / 8). With 11 posts anchored, I should be ok I hope.
/ Pole barn...anchor posts? #9
The pole building book I have was written before the change in pressure treating, but one of the suggestions is to insert lag bolts in the pole below ground and then pour concrete. Maybe there are some very well galvanized lag bolts available. Seems like the other suggestion I've come across is that the edgs of the hole be smooth so the frost doesn't get a better bite on the whole thing.
/ Pole barn...anchor posts? #10
Crushed stone on the bottom, and cemented 6x6pt.
Shane
/ Pole barn...anchor posts? #11
I always drill a hole thru opposite side and run a piece of # 5 rebar thru each hole about half way down into the concrete.
/ Pole barn...anchor posts? #12
I like the pressure treated cleat idea. If you cannot readily find Ground Contact 2x material, rip a 4x4 in half. Quick, easy and cheap. The rebar drilled into the sides and set in concrete is a good iea also. I wouldn't worry too much about corrosion since the footings should be dry (make sure they are dry; this is your shed).
Just a FYI, I saw a pole barn (pieces of it, that is, scattered all over the countryside) and EMPTY holes where the shed used to stand after an updraft sucked it out of the ground..... 6x6 posts set on concrete cookies 48" down, no anchors.
/ Pole barn...anchor posts? #13
I don't agree with your PT lumber retention numbers. I am thinking that the wood from Home Depot is treated to .40 and you need at least .60 for inground posts. Someone correct me if I am mistaken.
The builder I used to haul materials for used the cleat method Cleridon mentioned on concrete pads (bagged or poured depending on the customer and code) backfilled with earth or concrete again per customer and code. The cleats should be predrilled so they do not split.
Whatever you do, you need to use the proper fasteners or they are not going to last.
davitk said:
.25 above ground, .40 ground contact, .60 permanent wood foundation, per American Wood Preservers Institute, www.awpi.org
I should have been more specific. I'm not talking about CCA or ACQ. My lumber yard carries "Wolmanized" brand of Copper Azole (CA-B). There are many different formulations out there now, which leads to even the lumber yards being very confused. They should have standardized around a specific nomenclature, regardless of the formulation. Something like AG-Above Ground, GC=Ground Contact and BG=Below Ground.
Pressure Treated Lumber - Conrad Forest Products: 800-356-7146 CCA- Wolmanized Outdoor Wood
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2022 EZ-GO ELITE...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
