Pole Barn advice
/ Pole Barn advice #71
Great looking building.
Army Grunt
/ Pole Barn advice
Well I can at least park in it now.
I need to start looking into insulation, electrical and water. Actually I should have already been into it more but I've been too busy with work this month.
/ Pole Barn advice #73
Now that's what I'm talking about! Very nice AJE. Can't wait for ours to go up.
/ Pole Barn advice #75
More questions AJE.
How big is you garage door? How wide is it?
Wedge
/ Pole Barn advice
Gizmo, the roof is 5/12
wedge, the garage door is 16'x9'. The back door is 10x10, two five foot sections.
/ Pole Barn advice
Another update.... I've been a busy boy over the last month.... started on this phase in September.
Ditch for water and electric
Deck torn apart for access
Up against the foundation of the house
Most of the trencher work done
Underneath the splash board for the hydrants
From the inside
/ Pole Barn advice
Two days later, we have a helluva rain storm and it's totally full of water...
After it dried a bit, I drilled through the foundation, installed a PVC sleeve, and then the water line...
End of the sleeve, at first turn
Sealed up the foundation before covering it up
Busted through the wall in the garage to run the wiring through the conduit...
Started hanging the PVC for the electric...
/ Pole Barn advice
Got the water ran from inside the basement over to the corner of the foundation
Finished running the water line, hooked up the hydrants, and then bury them (after successful test)
Here is the inside where the electric sub panel is going, after the conduit is ran...
/ Pole Barn advice
Finished up under the deck, just need to bury, grade, and replace the decking...
Ran an extra 2" for communications... will finish running what I need at a later time, but it's ready to go when that time comes.
Say goodbye, finish buying conduit...
It then sat for a couple of weeks while we went on a family vacation. The electrician then came and we got the sub panel installed. I ran a cheater outlet underneath it for temporary use over the last several days have started running electric.
Trench is settling some, too
Panel setup as I'm working on it....
First outlet (mounted on rafter for garage door opener). Successful test!
Last night I put two lights in the back on one curcuit (had planned on three but it was pretty bright as it was). Then hung up three in the middle, and one over top of the walk in door.
Now that I gather the pictures it seems like it was a lot easier than it was. I assure you it was a lot of work with this one man, sometimes two/one ladder operation! Funny how that works.
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2021 Caterpillar 299D3 (A60462)
2021 Caterpillar...
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2017 Ford F-550...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
