plugging air filled tires
/ plugging air filled tires #1
terramite t9
how and what do u use to plug your tires if you have a leak. does slime work?? also, what can i use to solid fill my tires?
/ plugging air filled tires #2
I recently started using gemplers ultraseal.... Following 3 flats on one job in a week. It is now in the tires of all my rolling gear. The first job I did after filling the tire was to load 60 yards of mixed household trash and fire debris. This was in my power trac 1850. It's articulating steering is especially hard on tires. I pulled BIG nails, 2" embedded glass even a thumb sized stick. No flats. I'm fully sold on the stuff.
It stays fluid and is far more comfortable than solid, foam tires.
Ultraseal is not like green slime and other box store type products. It does not rust rims.
The pump is a bit expensive but a big help.
I could be convinced to lend mine for postage and a deposit...
has anyone tried TIREJECT?
i put tireject in my two rear t9 tires and its working so far. i put 22 oz. in each tire.
/ plugging air filled tires #5
Cool! I want a picture of something scary sticking out of the tire w/o pressure loss though
