Plugged Pond Overflow Pipe
/ Plugged Pond Overflow Pipe #1
rekees
Indiana, USA
JD4300 HST
I know this question doesn't relate directly to tractors but perhaps it qualifies as a rural living issue? Last Summer bought a farm that has a 2 acre pond. Unfortunately the previous owner didn't put a screen on the overflow drain pipe and now it appears to be about 90% plugged up. Water still flows thru it but so slowly that it takes weeks for the pond to return to a normal level after a heavy rain. I was wondering if anybody has experience/suggestions on unplugging such a pipe? The pipe is 4 inch PVC, 200 feet long and underground except for the ends. The ends would be difficult to access since the inlet requires standing in 3+ feet of water and the outlet is 1 foot below ground level in a hole. Is this a do-it-yourself project or will a plumber or pond professional be needed?
Chuck in IN
/ Plugged Pond Overflow Pipe #2
How about blocking it off completely and then when the water is say 6"-12" over the top, open it up and let the water force clean it out. I don't know it this will work for you or not, but water is mighty powerful and will clean out a lot of rock and sticks that may be blocking.
Von
Von - Yes, I know the power of water. Just look at the Grand Canyon! The water gets over the top of the inlet whenever it rains heavily and the water pressure doesn't clean it out. I don't know what the plug(s) is composed of. Doubt rocks but could be sticks or fish, frogs, cattails, leaves and various other assorted pond related things that would fit into a 4" pipe.
Chuck in IN
/ Plugged Pond Overflow Pipe #4
I would get in a boat and try to send a drain snake down and see if that helps.
Von
/ Plugged Pond Overflow Pipe #5
rekees,
Maybe this will help.
Float a string or a rope thru the pipe,than tie a heavy rope on to that than pull that thru.
Now tie a old set of tire chains to the rope,but before you pull the tire chains thru,tie another rope to the other end of the tire chains.
Just pull the rope thru the pipe and should loosen up up things,but you may have to do this more than once.
If the tire chains should become stuck you can pull on the other end to free the chains.
I would always leave a rope in the pipe for future use,and maybe 4 or 5 times a year run the chain thru.
Thomas..NH /w3tcompact/icons/wink.gif
/ Plugged Pond Overflow Pipe #6
I think Thomas's idea has a lot of merit but I think the biggest problem is an undersized pipe. A 2 acre pond is pretty large and even an unobstructed 4 inch pipe is going to take a large time to drain off that much water. You may find you don't even have a blockage to speak of, just an undersized pipe. Just off the cuff I'd say you could have gone with a 12 inch pipe and still not be too large for that size pond. (With a little research you should be able to find the flow rate for 4inch pipe in gallons per hour for a specified head, then do a rough estimate on how much water is in your pond per inch. The only hard part is not knowing how much water runs into the pond from the adjacent ground. Lets say you get a 1/2 inch of rain. You would raise the pond level by that half inch plus the amount you get from the "watershed" for that pond. 1/2 inch for 2 acres equates to about 53,000 gal of water assuming zero runoff. That much water running through an unvented 4 inch pipe by gravity alone is going to take a l o n g time. Sounds like you have a great excuse to buy a backhoe attachment and lay some drain pipe!!)
/ Plugged Pond Overflow Pipe #7
I think Gerard hit it on the head. I was going to say the same thing and I'm glad he got there first. He was much better with the math. We have a 3 acre pond at the inlaws house and over flow pipe is about 16". Might need to check with a pro.
MarkV
Thomas
Thanks for the suggestion. It may have some merit though I think it would be difficult to float the string or rope thru the pipe. Especially with the blockage in there somewhere. Have tire chains but pretty sure they wouldn't fit into the 4" pipe. Maybe I could use some other smaller object? Have to think about what.
Your approach is food for thought and I will consider it in the Spring.
Thanks.
Chuck in IN
gerard
Maybe a 4" pipe is too small but that's water over the dam (no pun intended). The last resort will be digging up the pipe and installing new pipe. A backhoe for my JD4300 would be $7000. For that kind of money I can live with the slow drainage.
There is definitely blockage because I've looked at the water coming out of the outlet and it's just about the rate you'd expect out of a garden hose! Also when the flow stops the level of the pond water is even with the top of the inlet. This tells me that maybe the blockage is near the inlet and may be relatively easy to reach?
Chuck in IN
/ Plugged Pond Overflow Pipe #10
Like Gerard and the others, 4 inches sounds a little small for any kind of outdoor drainage, but since it came that way and you're talking 200 feet, I guess you'd really like to make that work.
Since it's the size of household drainpipe, I would suggest you try household drain cleaning techniques. If you can't snake it out from the ends, you might get one of those rubber bladder things that attaches to the end of a hose (assuming you can get a hose to one end of the pipe). Can't remember exactly what they're called (plumbers affectionately refer to them as "douche bags", but this is a family-oriented message board so I will not use that term), but after you attach it to a hose, you shove it as far into the pipe as you can and then turn on the water full blast. The rubber bladder expands and seals itself inside the pipe so all the water pressure has to go out the other end. The downstream end of the thing has a relatively small aperture, so you get a pretty good "jet" of water.
If necessary, you might consider fashioning your own temporary pressure cap on the pipe. It wouldn't take much to put a cap on the end that you've adapted with some kind of hose fitting. The idea is to use hydraulic (how appropriate) pressure to get the job done. Even if you get it only partially cleared, you could then use this pressure system to force a "mouse" (something like a tennis ball) through, pulling a line. Once the line is through, you can try some of the methods that Thomas suggested.
If none of that works, it might be time to call Roto-Rooter (do they have those where you are?).
I guess all ponds are different. Mine, for example, has 3 main inlets which are fed from mountain runoff. The combined water flow can be tremendous at certain times of year, so our overflow is a tad larger than yours -- namely, four 36-inch diameter pipes (see attached). Of course, we only had to route it past the dam, which is about 20 feet at that point. /w3tcompact/icons/wink.gif
Harv
In order to fomulate a solution to a problem it's always best, if possible, to understand the root cause. I need to do some poking and proding into that pipe to figure out where the the blockage is located and what it consists of. That's the first step.
I have garden hoses galore but it never occurred to me to use them until you mentioned it. Thank you. The pond is in fact close enough to the house that it would be feasible to reach the pipe and connect the hose(s) to an outdoor faucet. May have to buy another hose or 2 to reach the pipe outlet but one can never own too many hoses. :) Never heard of those rubber bladder thingies but maybe if the blockage is mud that would work?
As far as Thomas' suggestion, maybe I could attach a fishing float to a strong nylon fishing line and send that thru first. Then use the fishing line to pull a stronger rope thru? Then the stronger rope could be used to pull tire chains or whatever thru to remove the blockage. I don't think the pressure cap technique would work since the pipe is only partially blocked.
Don't know about Roto-Rooter. Was thinking maybe the local hardware store would have a similiar device for rent? Will have to check it out. Live 50 miles from Cincinnati and know they have Rooter folks there. Probably cost an arm & a leg for them to do it but guess they could handle it?
Thanks for the picture. You really have some serious overflow drains for your pond, Harv! They could handle my whole 42 acre farm!! Yes, they are a "tad" larger than mine. :) I guess the 4" pipe on my pond was only designed to handle small rains? There is a spillway at the end of the dam that will handle overflow if the water level gets about a foot above the pipe. I agree that the pipe should have been bigger but it's too late to change that now without digging a huge trench thru the middle of the dam to replace it. The drainage area is two small valleys. Guess it's less than 5 acres? The previous owner said it rained so hard one time that water went over the spillway and there were fish in the pasture! Wonder what the cows thought about that!? hahahaha
Chuck in IN
/ Plugged Pond Overflow Pipe #12
ok so you're stuck with the 4 inch pipe. Try a 50 foot snake and see what you get. You might find that over time the first section of pipe acts as a settling chamber and fines and silt deposits and accumulates since the flow is not fast enough to carry them all the way through. (How "pitched" is the pipe??) If that's the case you ought to be able to clear it out with a combination snake and hose to flush everything through. A plumber with a power auger could take care of this in about an hour. Figure maybe $100?? They have augers with blades on the end that are the inside diameter of the pipe. They'll go through tree roots with no problem so a little mud would be simple. Might be the easiest route. You also may be able to rent them. Once you get it cleared I like the idea of leaving a small string (some 100lb test fishing line comes to mind) in place to use to pull through heavier rope in the future. Then I'd rig up a circular piece of wood a little smaller than the inside diameter of the pipe and use that to pull through once in a while if it fills up again. Guess it depends on how long it goes before stopping up.
gerard -
The pond was built 25 years ago so apparently that's how long it take for the pipe to become blocked? Really appreciate your suggestions and advice. Wasn't aware of the power auger tool and $100 would be worth not drowning. Need to find out location and extent of blockage then develop solution based on that knowledge.
After it's cleared I'm going to put a screen on the inlet to keep out the larger debris and if I can get a fishing line in there will do that also since a screen wont stop mud. Also read somewhere that the inlet should be cut back at an angle underneath for a few inches since that is suppose to help the flow rate. Hopefully, everything will be in working order this Spring. Oh the joys of rural living! :)
Did you ever notice that the more stuff you own the more it owns you!
Chuck in IN
/ Plugged Pond Overflow Pipe #14
Rekees, just one more possible option for your bag of tricks. Out my way the local volunteer fire depts. are more than willing to assist in clearing blockages in culvert pipes using their high pressure water pumps. Might be something to consider along with the garden hose idea. Good luck.
/ Plugged Pond Overflow Pipe #15
Don't know if it would be worth the trouble but digging it up in about the midpoint and putting in a vent stack would help increase the flow also. Wouldn't be hard to put in a tee with an 1 1/2 inch "chimney" to help vent it. You could also consider "marrying" some 4 inch perforated drain tile to the pond end, maybe 10 feet worth and using that as a "settling chamber". Then all you would have to do is clean that section. Of course if it took 25 years to clog I think I'd leave it alone!! (The volunteer fire dept is a great idea, they could get some serious flow through there. I'd rather "donate" the money to them than pay a plumber!)
/ Plugged Pond Overflow Pipe #16
Chuck,
Hopefully this is not something you have to worry about but....
Have you thought of liability if the overflow pipe is too small? If your dam fails is there enough water in it to damage anything below the pond? If not who cares! :cool: But if there is....
Where I used to own property there was a land owner that had several dams where not being maintained. His overflows were clogged and the dam faces were being erroded from overflowing water after heavy rains. We had a very expensive bridge downstream of his dams. The home owners association paid an engineer to look at this problem along with some other issues. He was very concerned that if the upstream dams failed the bridge would be washed out and half the people in the subdivision would not be able to get to their houses. As it was, some very heavy rains would cause river water to backup OVER the bridge preventing access. This never caused any damage just inconvience.
But the dam failures could wash out the bridge which I think cost 75,000 dollars to build a long time ago. Needless to say the home owners were very nervous about having to pay for a new bridge. Obviously, the dam failures would have cause the owner to be sued.
I had enough of that group of YaHoos and sold my lot a few years later! :cool:
Just food for thought...
Dan McCarty
Dan
Liability due to dam failure isn't something I have to worry about. I'm out in the boondocks so there aren't any bridges or homes to worry about. The pasture would get wet, the creek would rise, and I wouldn't have drinking water but that's about it.
There is a spillway that takes over when the water gets about a foot above the pipe. So there's no way the water can go over the dam no matter how hard it rains.
I would never live in a place that was subjected to the rules of a homeowner's association! Already subjected to county, state and federal laws so certainly don't need more rules! It okay for folks who like to see and be seen and keep up with the Jones but that's not who I am.
Chuck in IN
/ Plugged Pond Overflow Pipe #18
Chuck,
From your first notes I did not think the dam had anything down stream but I figured I would ask just to make sure.
The dams I worried about also had spillways but beavers had blocked them so they no longer worked. He was an idiot tree hugger type and did not want to bother the little critters. Heavy rains would then just wash over the face of his dams. Really dumb on his part.
That was my first and hopefully last dealing with a Home Owners Association. Well, my current property has a HOA but I own 10 of the 15 lots. Three of the five are owned by friends of ours. The owners of the other lots are in the south west and we get along just fine with the remaining owner. We are going to have to do something about road costs because they are not in the covenants. The subdivision never got built because the land perks real bad or not at all. So it was perfect for us to buy. Plus the price was real real real good! :cool:
What is funny, well you can either laugh or cry, so I'll laugh, is that one of the neighbors, but not in my HOA, is the exact same type of idiot that I had problems with in the last HOA. I guess it just does not matter, there are idiots not matter where you live....
She has given one of her neighbors a lot of grief because she thinks THEIR land is part of her lot. Her dogs poop all over these peoples property and chase your car when you drive by their house. This same bozo called the Sheriff about my timber operation which is really stupid since everything that was being done was legal and had nothing to do with her. Even if it had something to do with her its a civil matter and not criminal. I think she also called the law one day when I was target shooting as well. The icing on the cake is the yahoo wants to walk up my road for excercise. I guess you have to have one in every community. I sure seem to find 'em. :cool:
I wish I had the a little bit of money, maybe a .001% of Ted Turners, so I could just buy one 1,000 acre property..... Well I guess I would need a bigger tractor as well! :cool:
Later...
Dan McCarty
/ Plugged Pond Overflow Pipe #19
<font color=blue>...she also called the law one day when I was target shooting ...</font color=blue>
Soooo, what was your target /w3tcompact/icons/wink.gif?
<font color=green>mark</font color=green>
/ Plugged Pond Overflow Pipe #20
|...she also called the law one day when I was target |shooting ...
|Soooo, what was your target ?
It was a paper plate! I'll swear to the judge it was a paper plate! :cool:
The neighbor she is really annoyinglikes to target shoot as well. I'm sure he is reversing the annoyance factor. :cool:
I just wanna be left alone! :cool:
Later...
Dan
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
