Plow setup?
/ Plow setup? #1
Bill_C
Gallatin TN
Ford 1100
Okay, I read through the other plowing thread and it mentioned setting up the plow. I'm a complete beginner with a plow...This is a single bottom plow the FIL gave me. It's got a sharp disc, then the curved part of the plow (see, I don't even know basic plow terminology). This part is maybe 12 inches high. There's also a steel wheel about 2" wide behind the curved part, looks like this must control the depth the plow will go.
I played with the toplink a little and got the plow to cut about 2 inches deep, enough to lift the sod and roll it over, but that's about it. This is on hard Tennessee ground that's probably never seen a plow. Sometimes it tries to go deeper but it stops the tractor cold (Ford 1100, 2WD, got rear wheel weights but only turf tires).
How do I set up a plow? What's the basic parts of a plow? Do I need to ditch the turf tires and go for ags, plus adding more weight (tires aren't loaded)?
Thanks, as you can tell I ain't no farmer...yet.
/ Plow setup? #2
Well, my Dad loved plowing far too much to ever teach me how to set up the plow, but maybe I can help a little. I would drive the "high" side of the tractor (when viewed as it would be when plowing) up on to something 4"-6" high so you can stand behind the tractor, and see what is going with the plow as it would be in the furrow. Next, I guess I might adjust the plow on it's frame so that the outside of the "furrow" we are creating here is even with the inside of the back tire. I would then make other adjustments as required so that the plow was sitting flat on the ground, and tracking parallel with the tires of the tractor. Then I would set that depth wheel so that it was about 5"-6" above the ground, and give it a try. We can both learn the names for all these parts after we are having some fun using them.......... :D :D
/ Plow setup? #3
search, farmwithjunk has a great thread on how to set one up complete with pics
probably in the implement section.....
/ Plow setup? #4
if you are turning sod and the ground is hard you may not have enough pull to get your plow any deeper. have you tried to make 2 passes, the first one to roll the sod over and the next to turn the soil?
2013 John Deere 7200R Tractor (A66285)
2013 John Deere...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2021 CATERPILLAR 279D3 LOADER (A64553)
2021 CATERPILLAR...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
(4) Brawler 40 x 9 x 13 Skidsteer Tires (A66408)
(4) Brawler 40 x 9...
