Plow repair
/ Plow repair #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
I picked up an old MF #62 2-bottom plow a month or so ago. It's been over the mountain and seen the elephant in the years since it was new, and I seriously doubt it's ever seen the underside of a roof in all those years either.
The crossbeam adjustment was seized solid on two of the U-bolt ends, one shin was in rough shape, and the bottom corners of both mouldboards were worn to a knife edge.
I backed up the shin with some steel, welded it in place (stick and 7018).
The mouldboards got the same treatment, then ground back to the original profile.
I had to zip-cut two of the adjustment U-bolt nuts off, the threads were mangled beyond any hope of repairing them.
I got the MIG out, built up the threaded areas, then ground and filed the repaired area down to close to the original size. A pass with a die nut, and the job was done.
Sean
/ Plow repair #2
looks fantastic
i had my dearborn twin 14" buried today tilling tomatoes under
/ Plow repair
Thanks guys,
If it hadn't been for one of the U-bolts being loose, I probably would have left them alone on the chance it wouldn't need adjustment. Once you're into it, it's a case of now I HAVE to do it..
Sean
/ Plow repair #5
wow.. you went to alot of work to save that ubolt.. and it looks good. I have had to simply make new ones before out of round stock, benting them around an anvill with heat, then threading them. I like your approach. it's nice to save oem parts.
good job!
soundguy
/ Plow repair #6
looks good, I've also done the same as Soundguy with round stock.
/ Plow repair
That's what I get into with weekend jobs. Nothing open on Sunday near me, and no source of bar stock for sure. I was thinking, "I could do this on Monday, but I'd like to get it painted this weekend."
One of the really nice things about having welders is you can build most things if you don't mind putting the time in.
Sean
/ Plow repair #8
Ok...thats pretty impressive. Nice job!
Is it difficult to re-thread that u bolt with all that weld on it? I suppose you file it down first, right? Sorry if thats a dumb question.
/ Plow repair #9
he's have to file, or otherwise grind it down to the nominal diameter for the die/threads.
soundguy
/ Plow repair #10
Seems this was stated way on earlier.:D
/ Plow repair
I did have to grind it down first, a combination of both the bench grinder and an angle grinder for the tough-to-get-at areas did the job. A few strokes with the file and it was ready for re-threading. I left a couple of original threads at the outer ends to ensure the same "start" to the threads.
I must have pretty close to the right amount of threaded area, I got them pretty tight and nothing showed any tendency to strip.
Now that it's ready for adjustment, I'm willing to bet I won't need to move it at all..:)
Sean
/ Plow repair #12
Looking at that repair made me think and believe that Chilly could weld silly putty to a windshield and make it stick!!, looks perfect and expertly done, thanks for posting.
/ Plow repair
Thanks Bruce,
I am strictly an amateur when it comes to welding, but I enjoy doing it. Lucky I was able to get the adjustment, it needed quite a bit to get the plow working right.
Sean
