Plow for a GC2400
   / Plow for a GC2400 #1
bakerg
Elite Member
Tilbury, Ontario, Canada
John Deere D110
I have an old 2 furrow pull type plow on steel wheels that I was thinking of converting to a 3PH version. Will my GC2400 pull a 2-14" furrow plow or should I cut it down to 1 furrow.:confused2:
   / Plow for a GC2400 #2
I don't know for sure, but my 10 hp Bolens pulls a 1 bottom. So I would bet on the GC pulling 2.
A lot has to do with how it's set up.
   / Plow for a GC2400
Heres some pics of the plow Im thinking of converting.:D
   / Plow for a GC2400 #4
Why not try it as it is before tearing it apart to see it fail?
   / Plow for a GC2400 #6
I use a single furrow [old horse plow] behind my GC 2300,thats been converted to 3 pth.It pulls it but needs to be in 4x4 and even at times I have to lift it up a bit as it will make the tractor spin out.I just have turf tires BTW. A two bottom would be to much.We have heavy clay base soil so its tough to plough at the best of times.Larry
   / Plow for a GC2400 #7
Turf tires are great until you want to use ground engaging equipment like a plow. Then, for best performance, it's a good time to chain up the rear tires.
Getting the angles, and the depth set right are important. Many mold board plows have a disc cutter that runs in front which could be helpful. I am not sure, I never took mine off to see the difference.
But, like I said, I can pull a singe with my Bolens, so the Massey should be able to beat that.
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
2000 BMW  740IL (INOPERABEL) (A52472)
2000 BMW 740IL...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
