Plow for a GC2400
   / Plow for a GC2400 #1
bakerg
Elite Member
Tilbury, Ontario, Canada
John Deere D110
I have an old 2 furrow pull type plow on steel wheels that I was thinking of converting to a 3PH version. Will my GC2400 pull a 2-14" furrow plow or should I cut it down to 1 furrow.:confused2:
   / Plow for a GC2400 #2
I don't know for sure, but my 10 hp Bolens pulls a 1 bottom. So I would bet on the GC pulling 2.
A lot has to do with how it's set up.
   / Plow for a GC2400
Heres some pics of the plow Im thinking of converting.:D
   / Plow for a GC2400 #4
Why not try it as it is before tearing it apart to see it fail?
   / Plow for a GC2400 #6
I use a single furrow [old horse plow] behind my GC 2300,thats been converted to 3 pth.It pulls it but needs to be in 4x4 and even at times I have to lift it up a bit as it will make the tractor spin out.I just have turf tires BTW. A two bottom would be to much.We have heavy clay base soil so its tough to plough at the best of times.Larry
   / Plow for a GC2400 #7
Turf tires are great until you want to use ground engaging equipment like a plow. Then, for best performance, it's a good time to chain up the rear tires.
Getting the angles, and the depth set right are important. Many mold board plows have a disc cutter that runs in front which could be helpful. I am not sure, I never took mine off to see the difference.
But, like I said, I can pull a singe with my Bolens, so the Massey should be able to beat that.
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
