Plot in Lumber trails
/ Plot in Lumber trails #1
Vern
Good morning
I closed on 24 acres in Southampton County VA on Friday. The pines had been thinned earlier in the year but they left one heck of a mess. The trailes are piled with cuttings and needles and they left stumps up a couple inches.
To be able to plant a small food plot this spring I need to get the stumps out (6 to 12" diameter) and the cutting up.
I am going to make a brush fork for the FEL but any suggesations on the stumps?
Vern
/ Plot in Lumber trails #2
Back-hoe........rent if you have too.Better plan on limeing...high acid soil with all the pines.If they had left the stumps high you may have been able to pull with a tractor.
/ Plot in Lumber trails #3
+1 on the backhoe:thumbsup: unless there is only a few, like 2!!:D
I have dug out stumps (Oak) with my tractor and it is a labor of "love" for sure. Backhoe is 100 times faster. Use your tractor to do the "finishing", filling holes and smoothing.
I am looking at possibly 20 to 30 stumps in the first area. I would like to take them all but thats hundreds.
/ Plot in Lumber trails #5
excavator, probably don't need a real big one somewhere around 12000 lbs for that size stump. Will make short work of it. get the largest one with a blade you can dig and smooth all at once
/ Plot in Lumber trails #6
You could use the stumps as fencing too, puting them around the property to control where the deer can enter your property.
/ Plot in Lumber trails #7
The lowest pH I've ever seen came from 30 miles from you. Came back at 4.2! Needed a ridiculous amount of lime, especially for a sandy soil.
Cant emphasize a soil test enough, nothing will grow that low.
/ Plot in Lumber trails #8
I have used a stump grinder to remove over 1200 stumps from my land. First I used a rental grinder(s)....and took about 200 per day of pine stumps. Later I bought a 3 Point Woods Grinder for my tractor and have taken about 600 stumps with the tractor.
For 30 stumps.....I'd rent a 25 HP Raygo or Vermeer self propelled.....and have them gone in a few hours. :thumbsup:
/ Plot in Lumber trails #9
If you are renting a mini exc. get one with a thumb it's the only way to go
/ Plot in Lumber trails #10
If it were me I would plant around the stumps and wait for them to rot. Pine stumps usually rot within four years.
4 years? not sure I can wait that long....hopefully the tractor will be done soon and once the cuttings are gone I can see what I am dealing with
/ Plot in Lumber trails #12
Rent a Mini-excavator with a thumb, lot smoother than a wheel backhoe and more fun too! . . .John
/ Plot in Lumber trails #13
They may rot that fast in Missisippi.....but in our sandy soil they will last a long time. Maybe a decade or more. For Pine stumps......grinding is the best way for me...... much faster.......and when your done you dont have stumps to bury or burn or haul. :thumbsup:
/ Plot in Lumber trails #14
Same here in Florida, termites will see to it, and if you want to speed up the process throw a little dirt on top of the stumps.
/ Plot in Lumber trails #15
Here you will see what looks like a solid pine stump and its only a shell. You can step on it and the stump will fall apart.
/ Plot in Lumber trails #16
I did that in one of my bottom fields, the problem was the yellow jackets that turned it into a home hated me kicking their roof in. Only stung 3 times, it could have been worse.
/ Plot in Lumber trails #17
I concur with others you can rent a stump grinder and get 20-30 6-12" size in a day maybe more.
Grind them 4-6" below grade then disc the area once you have all the bigger brush cleaned up will level it out and cut up the needles/leftover branches into a finer mulch mixed with the chips. Then a lot of lime some fertilizer and seed of choice.
Depending on your soil if its rocky stumping will leave you with a big mess of roots and rocks to clean up plus I have found 10 years after stumping the ground settles more vs where the stumps were ground down. These were big pine 30-40" across the stump at ground level so when you dig one of these out they are 5-6' in diameter and weigh 1000+lbs due dirt and rocks embedded.
/ Plot in Lumber trails #19
Here's another pic of our trails that wind through the woods....and a rental grinder I used before buying my Woods 3 point grinder. Also a pic of liming my trails / plots.
I paid about $150 per day (plus fuel) to rent the self propelled 25 HP grinders as shown. I could grind up to 200 pine stumps per day with one of these machines. Most of my stumps were sheared off a few inches above ground and were 12 to 14" diameter. Your results may vary. ;)
Your trails look great, exactly what I am going to do. Ginding just seems like such a slow way of going. I have used a similar grinder but it was on some pretty big stumps 30 inch diameter. I have some time coming in March I will have to see about renting one.
Thanks
New/Unused AGT Industrial Gas-Powered Air Compressor (A61166)
New/Unused AGT...
Welcome to the Ranch Metal Decorative Sign (A61569)
Welcome to the...
2018 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-2632...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2015 Ford F-150 Pickup Truck (A60352)
2015 Ford F-150...
