Please scrutinize my welds.
   / Please scrutinize my welds. #1
pickeringchris
So I haven't done welding of any sort for 25 years and had never done arc welding of any kind. A month ago I picked up a Lincoln 180 and a tank of c25. I watched a million videos online and dove in. So far I have used up about 4 lbs of .030 MIG wire. That is my entire mig experience.
I follow the feed/voltage chart on the inside panel pretty closely and much to my surprise I was making ok welds within 10 minutes. When I say "ok welds", they look ok to me. :). Can't be this easy????? Honestly, I don't have a clue if my welds are good or not. No idea if they are structurally sound. How do I tell?
Here is a couple pics of some practicing I did on a 3/16" thick pry bar. Can you guys tell me what you think?
Also a d ring I attached to my bucket.
Cheers.
Chris
Drawbar. 3 passes per side.
   / Please scrutinize my welds. #3
   / Please scrutinize my welds. #4
Here's a vertical up Mig weld I made with Lincoln's L-56 wire. See how hot it's burned in? For structural Mig welds you want to run as hot as you can handle it! ;)
Shield Arc said:
I'd throw that chart away! The welds in the second picture are a little cold, (or your travel speed is way to slow). Back off on the wire speed / amps, or turn up the volts.
Here's a thread I did on testing Mig welds. Did other tests you might be interested in too.
http://www.tractorbynet.com/forums/welding/212146-mig-break-test.html
Thanks so much. So when you say "cold" you mean poor penetration correct? So wouldn't I have to slow down my travel speed or turn up volts or both???
Also, I have a # 11 filter. I feel like its a little too dark. What can I safely use??? 9?
   / Please scrutinize my welds. #7
I am just using what ever came with my helmets right now. One of them is a #9, and I think the one I am using now is a #10. You might want to get an auto dark, I hear they make mig easier. I am getting one, it is in the mail now.
   / Please scrutinize my welds. #8
Cold as in too high of a profile / lumpy.
I use a #10 lens for most all my welding now a days.
But here's some charts for you.
I have a Lincoln auto darkening. It awesome but it's a cheap non adjustable version that came with the welder. Its fixed @ 11. :)
   / Please scrutinize my welds. #10
Ahh I got a lincoln on its way to me right now. Mine is adjustable from 9-13, and has a grind mode though. You can get the one I have for $150 at home depot (online only), it has the same filter as the viking 1840, but has a bit heavier shell, and differnt graphics.
2025 JOHN DEERE 2032R LOT IDENTIFIER 102 (A53084)
2025 JOHN DEERE...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2016 Mobility Ventures MV-1 VAN (A51694)
2016 Mobility...
2011 KMC 3376 LOT IDENTIFIER 244 (A53084)
2011 KMC 3376 LOT...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
