Please scrutinize my welds.
   / Please scrutinize my welds. #1
pickeringchris
So I haven't done welding of any sort for 25 years and had never done arc welding of any kind. A month ago I picked up a Lincoln 180 and a tank of c25. I watched a million videos online and dove in. So far I have used up about 4 lbs of .030 MIG wire. That is my entire mig experience.
I follow the feed/voltage chart on the inside panel pretty closely and much to my surprise I was making ok welds within 10 minutes. When I say "ok welds", they look ok to me. :). Can't be this easy????? Honestly, I don't have a clue if my welds are good or not. No idea if they are structurally sound. How do I tell?
Here is a couple pics of some practicing I did on a 3/16" thick pry bar. Can you guys tell me what you think?
Also a d ring I attached to my bucket.
Cheers.
Chris
Drawbar. 3 passes per side.
   / Please scrutinize my welds. #3
   / Please scrutinize my welds. #4
Here's a vertical up Mig weld I made with Lincoln's L-56 wire. See how hot it's burned in? For structural Mig welds you want to run as hot as you can handle it! ;)
Shield Arc said:
I'd throw that chart away! The welds in the second picture are a little cold, (or your travel speed is way to slow). Back off on the wire speed / amps, or turn up the volts.
Here's a thread I did on testing Mig welds. Did other tests you might be interested in too.
http://www.tractorbynet.com/forums/welding/212146-mig-break-test.html
Thanks so much. So when you say "cold" you mean poor penetration correct? So wouldn't I have to slow down my travel speed or turn up volts or both???
Also, I have a # 11 filter. I feel like its a little too dark. What can I safely use??? 9?
   / Please scrutinize my welds. #7
I am just using what ever came with my helmets right now. One of them is a #9, and I think the one I am using now is a #10. You might want to get an auto dark, I hear they make mig easier. I am getting one, it is in the mail now.
   / Please scrutinize my welds. #8
Cold as in too high of a profile / lumpy.
I use a #10 lens for most all my welding now a days.
But here's some charts for you.
I have a Lincoln auto darkening. It awesome but it's a cheap non adjustable version that came with the welder. Its fixed @ 11. :)
   / Please scrutinize my welds. #10
Ahh I got a lincoln on its way to me right now. Mine is adjustable from 9-13, and has a grind mode though. You can get the one I have for $150 at home depot (online only), it has the same filter as the viking 1840, but has a bit heavier shell, and differnt graphics.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
