Please help my neck....
/ Please help my neck.... #41
You guys are a HOOT...next winter I intend on replacing my 8' snow push with a snow blower...but I am NOT getting one that I have to drive backwards...my driveway is 1400' from the road to the house...I'm looking to find as many MFGs that make the rear PULL FORWARD and then I'll make a decision this summer and pull the trigger. I originally wanted the mid-mount PTO with the FRONT mounted snow blower, but they were just WAY too expensive!
/ Please help my neck.... #42
I plowed my mile long driveway, again, yesterday. No joy - no joy at all. I got it all cleared OK. It was the worst kind of snow - wet & heavy. Even at 10K+ pounds it pushed the Kubota around with a full rear blade. Turns a fun romp down the driveway into a real job.
I would not have plowed it - there was only about 6" of unplowed snow. The neighbor came over and asked if I would plow his. So while I got all bundled & everything going - might just as well.
This is the time of year when we normally will start getting rain. At least, there won't be so much snow to become gumbo.
/ Please help my neck.... #43
Main problem with a puller blower is that you need to drive thru the snow first.
OK when nice dry snow and not too deep.
I have a CUT and there times with wet 'snowman' snow that my wheels never make it to the road surface and only leave compacted lumps that nothing cuts thru.
IMHO only a real heavy tractor can take advantage of those style blowers.
12 inches of wet stuff would IMHO spell disaster for a cut pulling a puller blower, shucks even 5-6".
That 19 hp PTO would be fine in light fluffy snow but that is not always what mother nature gives us.
Also most CUTs don't have all that much clearance.
A couple around here I have seen being used. 2 feet of snow is no problem for them. They can slowly cut through the plowed snow at end of road or just move it with bucket. 5 to 6 inches of wet stuff is a cake walk for them.
/ Please help my neck.... #44
i looked into the pull style blowers also, but with the type of snow i move and the amounts, i could not drive over the piles towing a blower. I go thru piles 24 plus thick. When i clean up the building that shed and block horses out of their stslls, the snow csn be 4 feet deep
Not sure why your tractor would have problems driving over 24 inches of snow. My tractor is only 36HP and drives through that stuff like it's not there.
/ Please help my neck.... #45
I am getting an inverted blower next season, I already spoke to my dealer about the setup. Meteor and Woodhouse (Sundown) make some affordable ones.
/ Please help my neck.... #46
My thoughts too. I'm at 7100 lbs with filled rears, FEL, bucket and box blade. Most of the time I don't have to use my diff lock either. I have routinely driven through snow deeper than my tractor clearance, and not had any issues. 3 feet plus is not a problem, but I'm also on level ground, which helps, maybe these guys are on steep slopes, which changes everything.
/ Please help my neck.... #47
I still find that my heavy tractor plus heavy rear blade works best for me. I have a large valley in the driveway. At times, it means plowing down into the valley rather that up out of the valley. Only a minor inconvenience. The heavy, wet snow I plowed a couple days ago would have been a problem for any type of blower.
Besides - the heavy duty Rhino 950 rear blade is a much more universal implement. Probably even a little cheaper than a quality blower also.
/ Please help my neck.... #48
A blower works best for people that run out of places to put the snow. Happens a lot around here.
/ Please help my neck.... #49
I'll second the back blade.
I have a plow truck with a sander that I mostly just sand with.
On my tractor I have the FEL with the bucket and I have an 8 ft hydraulically angled SSQA blade and a 10 ft rear blade.
Much of the time I like the front blade as its easy to see what I'm doing.
Most of my driveway has a bank with 3 to 12 foot of drop off the side that I plow to, so no issue with the banks getting to high.
This year I have only used the front blade for a couple of storms.
We got a warm spell mid winter that thawed the driveway completely and it got quite a few wheel ruts in it which has made it rough for plowing.
The front blades are catching and tripping and jumping and jolting the tractor or truck.
I have been using the rear blade as it doesn't jump or jolt the tractor near as much an the jolting on the FEL bothers me, I worry about it causing damage.
The heavy rear blade pulls over the ruts with much less bouncing and jolting.
The front blade is nice when I push the snow banks back and over the drop offs as it's easy to see where the front tires are and how much they are starting to drop and the tractor will back out even if I get a front wheel over a bank a bit. I also will turn the rear blade around and push banks over while backing up at times.
I keep contemplating getting a blower, if I do I think I would prefer the inverted ones so as to blow while traveling forward.
/ Please help my neck.... #50
On another thread, leonz mentioned the Bercomac. It is SSQA mounted blower with a Honda engine. Having another engine is a PITA but being SSQA is great. No PTO issues, easy on/off, can put bucket, grapple or forks on when needed with out having to remount loader frame, keeps access to 3 pt, and drives forward. At $6k for a 54" it is not too pricey.
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2008 Sea Ray 260 Boat w T/A Boat trailer (A59231)
2008 Sea Ray 260...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
Rotary SPOA9-200 Automotive Lift (A59230)
Rotary SPOA9-200...
