Please help: John Deere 455 failed to start
/ Please help: John Deere 455 failed to start #1
Slmauro
Kintnersville, pa
John Deere/455
Hi, I have a 1994 John Deere 455. It was running pretty well, until the mower belt broke, then the tractor would not start anymore.
The battery was charged, but when I turned the key, nothing happened. Any recommendations would be greatly appreciated.
/ Please help: John Deere 455 failed to start #2
My first inclination would be the PTO switch is still on.
Second inclination would be time for a new battery... if the last new one was within 3-4 years.
:welcome: to TBN
Work with us, and we'll help get it running again.
/ Please help: John Deere 455 failed to start #3
The PTO would be my first guess too.
/ Please help: John Deere 455 failed to start #4
Were there shields in place on the mower when the belt broke? I'm wondering that if there weren't then it's possible the deck belt hit something, though I can think of what it could have hit down in that area.
Rick
:welcome: to TBN
Thank you all for your help. The PTO is not on. When I turned the key, it didn't turnover, there was no sound like it did before.
When the belt broke, the engine ran hot. That's when I discovered the belt was broken. I drove it back to the garage, turned it off to cool it. And it wouldn't start again :-(
/ Please help: John Deere 455 failed to start #6
I had a 445 if I recall the model correctly and it seemed there is a fuse that blew on mine a couple times and had the same effects.. Check the fuses.
/ Please help: John Deere 455 failed to start #7
Check wire connections. It may be coincidental but you may have a loose connection. Check ground wires as well.
/ Please help: John Deere 455 failed to start #9
I don't think the belt breaking could have caused the engine to overheat. Something else going on here.
Will need to learn more about the cause and effect in order to track down what happened.
Good idea to check the fuses and if the engine is seized up.
/ Please help: John Deere 455 failed to start #10
When you turn the key do you get any sound at all? Like a click from the starter relay or a sound like the starter drive gear trying to engage the flywheel? If not then you likely have an electrical issue going on first.
Rick
Thank you all for your replies. Based on your comments, I think my problem is electrical. When I turned the key, no sound, no light, nothing happened, so fuse and wire connection are the first on my list to check. Thank you!!
/ Please help: John Deere 455 failed to start #12
Do you have the service tech manual for your JD 455 ?
Have you browsed the suggested links at the bottom of the page, which are about previous threads on the 455?
/ Please help: John Deere 455 failed to start #13
Hot wire starter & fuel solenoid. If it cranks/starts, then problem is electrical.
/ Please help: John Deere 455 failed to start #14
Check the 2 15A fuses on the right side under the dash.
46197SFL (A64557)
46197SFL (A64557)
2015 Ford F-650 Altec AP40 35ft. Bucket Truck (A64194)
2015 Ford F-650...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
KUBOTA BX1870 TRACTOR (A65054)
KUBOTA BX1870...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
