Plastic Welding?
/ Plastic Welding? #21
Trails, Snow skis? We are professional ski instructors, wife and I. Nicole is a Senior Examiner for P.S.I.A. Time for dinner.
Yep- In my younger days- I'm really not that old :D I raced in the Northern Divsion( Wyo- Mont)- I really had a blast-We always were tuning our skiis-which often included fixing gouges in the base with p-tex.
My boards are a little old-I'm still able to ski most (to be read most :D) terrain-
/ Plastic Welding?
Trails, Thing is not many people even know what P-Tex is. I just dressed {tuned} wifie's skis for an event she is doing Monday. I was looking for Nicholson files Yesterday but only Chinese could be found and at Nicholson prices.
/ Plastic Welding?
Well! Thanks for the thoughts. Sounds like they[plastic welder] are good for thicker plastics and having the correct rod is the main concern. Didn't sound like many guys have gotten into plastic welding.
Is ABS usually black? The material that tool containers are made of looks like PVC as do plastic lawn chairs. I don't see anything around that looks like nylon.
Do you actualy touch the tip to the work?
/ Plastic Welding? #24
Yes, Abs is usually black. It also will soften with acetone, or lacquer thinner.
Abs is more easily solvent welded.
There are also hybrid mixes that have strange properties.
/ Plastic Welding? #25
If you're lucky the plastic has a recycling # to help id it. alot of black toolboxes are hdpe [#2]. years ago i welded plastic almost everyday at work. we did rehab on manholes for dupont,bfi,ect. you don't want to know what was flowing through them!:D
/ Plastic Welding? #26
I also have the HF unit. It can make strong welds, but not always pretty.
Here are some tips:
1. Notch the crack in a V shape where you are going to apply the weld (from the back when you can)
2. Keep the extra pieces you cut off and use them in the weld. This is the right kind and color, for sure :)
3. Try to weld from the back. If the pieces are put together very closely and held well while welding from the back, any front crack will be hardly noticeable
4. Have some type of "spoon" available to push/shape the plastic while still warm. These are more like hobby tools than a table spoon and are different sizes/shapes.
5. DO NOT OVERHEAT THE PLASTIC !!! Better to heat and weld, let cool and do some more. When you over heat, it will burn and/or shrink and make a mess. No burnt marks (bad!)
6. When using the rods, I've had the best success when cutting pieces and laying them into the V notches above, then heating. Sometimes better to place the pieces in the V before heating, sometimes have the pieces cut, heat the work material, then put the pieces in the void and heat. Depends one what and how you are welding.
7. Make sure everything is VERY CLEAN. Just like soldering, oils, dirt, etc will interfere with the bonding and results.
I've used this for repairing broken body panels on ATVs, motorcycles, etc. Along with a good heat gun to heat and take out kinks and bends, it has been a handy item.
Hope this helps!
- JC
/ Plastic Welding? #27
I had to do a quick repair on my son's 4 wheeler plastic plow blade. After trying an electric soldering gun which didn't heat a large enough area to be effective, I remembered a soldering tip I had never used, for a berzomatic torch. Got it out and after some experimenting, found I could lay it across the crack and stitch it together and it looked like frankenstein stitches but held it together and finished the job. Several days later, I picked up some of the rods at HF and melted them into the stitches just to fill it and the thing is still together 4 or 5 years later.
/ Plastic Welding? #28
discdoktr gives some very good tips. I have the same unit and have found that matching the plastic is a must. The easiest thing is to use some scrap plastic from the same source as filler. ie I keep a broken plastic water bucket around so when another one breaks, I cut slivers from the one bucket to repair the other one. Finding the right melting temp is important also. I broke a running board on our F250. Would have been $500 for a new one. I was able to jigsaw fit the pieces back together and did a tolerable enough repair that you wouldn't know it was broken unless I pointed it out to you. Paid for itself many times over, just takes some practice. (Though I find metal welding easier).
/ Plastic Welding? #29
Interesting reading. I have done many plastic welding projects just using a soldering Iron, will have to remind the wife I really am patient. Anyway people must be wondering who the crazy guy picking up broken sled pieces from the snow hill is. I have welded Fender liners, modified plastic air boxes by welding in larger inlets. Recently welded back on the plastic tabs to a head light after Junior had an accident. My biggest project was cutting up and rewelding a Fan shroud after putting a body lift on a 4x4. I have never has a piece break during regular use but its nice to know there are special welders for this stuff.
/ Plastic Welding?
Thanks guys for the info and feedback. Does anyone use a unit that has only a open tube tip? This welder has no paddles. The use of a spoon was mentioned in one post.
We have these heated water buckets in the barn, its only a mater of time when one will need repairing.
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
40 (A52708)
40 (A52708)
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
2014 Ford F-150 Pickup Truck (A59230)
2014 Ford F-150...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
