sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,670
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
There are gases that are put in bottles that will kill you upon inhalation of them! I happened upon 5 bottles that I could have just for hauling off, and had (just barely) enough sense to figure out what the gas was. It was something that would kill you with 3 parts per million if inhaled. I left them, and stayed clear of that place.
The outside condition of the bottle has very little to do with the condition of the bottle itself as far as passing a test. They should remove the valve, inspect the interior of the bottle, and pressure test the bottle, noting how much it fails to return to its original size before pressurizing. The amount it displaces in water volume and how much it fails to return to original shape are the criteria.
As far as the valve threads condition, you should probably make sure that the threads are clean and not damaged. If you find that there was an issue, it probably doesn't mean you ruined a regulator, because those stems on the regulator are replaceable. I have quite a supply of them stashed. I was recently working with a acetylene/oxygen torch, when the diaphragm in oxygen regulator went out. Changed to a brand new (but 20 years old) regulator and it went out immediately. I grabbed a Hydrogen regulator, swapped out the stem and put it into service as an oxygen regulator. (regulator was new, never used).
Got to love having a bunch of spares when you have limited time to do most of your work, and always on the weekends when nobody is open to get repair parts!
Just for the record, never use a regulator for oxygen that has been used for other gases unless you know that there are no residuals, especially oil or grease in any amount!
David from jax
David from jax
