Plasma cutter
/ Plasma cutter #1
ENG18LT
Platinum Member
Syracuse and Warsaw, NY
Mahindra 5530 4wd
Been tinkering with metal for awhile and have managed to get by mooching friends torches when a cut off wheel won't do the trick. The other day a buddy pulled out his plasma cutter and I was impressed. Enough that I may get one. Would like to do up to half inch, any suggestions?
/ Plasma cutter #3
I have the Everlast PP60 and never has a problem with it. I've cut over 1" with it but when cutting metal that thick it's a rough cut. But for 3/4" or less it's fine. I think the PP50 would cut 1/2" just fine. If you don't mind spending extra money you should also look at Hypertherm.
/ Plasma cutter #4
I recently had to bury my Hypertherm Max 20 after 21 years of service.......this time I replaced it with a HyperTherm Powermax 30. It will cut 1/2" on 220 volt input power, but it isn't as clean of a cut as if you were cutting thinner material.
Most of my cutting is 1/4" or under.
/ Plasma cutter
BrianR, most of what I tinker with would be 1/4" or less. I just don't want to be limited if I need to cut 1/2".
All the replies have been helpful thank you all
/ Plasma cutter
Jake98, I checked out the link and think something the size of th 60 would be good. How long have you had yours?
/ Plasma cutter
Is Hypertherm the ones with the tip that you can put right on the material as it has the built in standoff?
/ Plasma cutter #10
I've cut 3/4 with my PP50 with new consumables. It did well considering it was maxed out. With a roller guide like JJ linked to, I cut a few 8" circles out of 1/2" plate for a buddy. Worked fine. The nut behind the torch caused more problems with his lack of technique than the torch did. I am going to pick up some of those castellated drag tips for the thinner stuff though. Looks like it might work out nicely using a straight edge.
Ian
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Bobcat A770 (A60462)
OXBO PixALL Big Jack Mark III (A60462)
OXBO PixALL Big...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
pressure washer, and trailer (A56859)
pressure washer...
