planting timothy spreader setting??
/ planting timothy spreader setting?? #1
rilesdav
MA
Branson 6530c and Kubota BX25D
Hello,
I am going to be planting timothy hay on 1 acre of area that was just cleared and prepared for seeding. I have an Earthway spreader and was told I need 18lbs of seed per acre. I did some calculations and determined I would be on setting #4. A setting of #4 barely has the holes open. Does anyone have any suggestions as to what I could mix the seed with as a carrier to allow me to use a higher setting and have the seed spread more easily.
Thanks
Dave
/ planting timothy spreader setting?? #2
Sand? A starter fertilizer?
/ planting timothy spreader setting?? #3
Hello,
Thanks
Dave
What ever setting, the book calls for, I always cut it in half and double cover. This way, I don't run out of seed before I get over the field. Ken Sweet
/ planting timothy spreader setting?? #4
Hello,
Thanks
Dave
A push type spreader?
If that is the case you are going to want it going on pretty slow because an acre is a lot of area to cover with 18 pounds of seed.
Yes, push type spreader, a suggestion I got from the spreader company was limestone. Any thoughts?
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
6' X 20' TRI-AXLE GOOSENECK TRAILER (A64280)
6' X 20' TRI-AXLE...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
Caterpillar D6M Dozer Service and Parts Manuals (A63117)
Caterpillar D6M...
