planting timothy spreader setting??
/ planting timothy spreader setting?? #1
rilesdav
MA
Branson 6530c and Kubota BX25D
Hello,
I am going to be planting timothy hay on 1 acre of area that was just cleared and prepared for seeding. I have an Earthway spreader and was told I need 18lbs of seed per acre. I did some calculations and determined I would be on setting #4. A setting of #4 barely has the holes open. Does anyone have any suggestions as to what I could mix the seed with as a carrier to allow me to use a higher setting and have the seed spread more easily.
Thanks
Dave
/ planting timothy spreader setting?? #2
Sand? A starter fertilizer?
/ planting timothy spreader setting?? #3
Hello,
Thanks
Dave
What ever setting, the book calls for, I always cut it in half and double cover. This way, I don't run out of seed before I get over the field. Ken Sweet
/ planting timothy spreader setting?? #4
Hello,
Thanks
Dave
A push type spreader?
If that is the case you are going to want it going on pretty slow because an acre is a lot of area to cover with 18 pounds of seed.
Yes, push type spreader, a suggestion I got from the spreader company was limestone. Any thoughts?
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
John Deere 608C 6 Row Corn Head (A64119)
John Deere 608C 6...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
