sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,879
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
That sounds like some great pointers.. I'm guessing you start with bare root stock? Do you use any special potting mix in the buckets? I'm planning on putting a dozen or so trees in next year so much obliged for the tips !!
I get bare root in the early Spring via mail order and plant in a plastic pot roughly 9" by 9" with plain dirt from the back field. Potting mix will dry too fast in the sun. I line them up behind the house and broadcast a touch of 19-19-19 and we often water daily in the summer. It's easy since the hose will reach. Any weeds get sprayed with a mild generic Roundup solution.
In late August when we plant I dig a hole and put the potted plan in to see how it fits. When it does, I slice the bottom off the pot, put in back in the hole and slit one side to slip the pot off. Roots get minimal disturbance this way unless I slit them a little which is rarely. Don't do what these TV people do unless truly root bound, which is unlikely, or unless you want to set the tree back a year in growth.
This way has given me nearly a 100% success rate as long as I water for the first couple years when it's hot or dry. New trees love water and the right amount of fertilizer.
Mostly I do spruce trees and hardwoods but you can also dig volunteer maple trees this way. In fact, the maple trees in our yard blew in as seeds from the neighbor's place and we put the seedlings in pots. Any bare root or small tree does well in pots. Plus, if you live in a windy or cold area, tress started from seedlings fare much better than larger transplants.
I also know how to graft your favorite apple trees onto mail order apple tree rootstock with a near 100% success rate as well. Maybe over the winter someone will start a thread and I'll join it. This tree stuff is easy if you take the lazy man's way out.
