Planting Apple Trees
/ Planting Apple Trees #21
That sounds like some great pointers.. I'm guessing you start with bare root stock? Do you use any special potting mix in the buckets? I'm planning on putting a dozen or so trees in next year so much obliged for the tips !!
I get bare root in the early Spring via mail order and plant in a plastic pot roughly 9" by 9" with plain dirt from the back field. Potting mix will dry too fast in the sun. I line them up behind the house and broadcast a touch of 19-19-19 and we often water daily in the summer. It's easy since the hose will reach. Any weeds get sprayed with a mild generic Roundup solution.
In late August when we plant I dig a hole and put the potted plan in to see how it fits. When it does, I slice the bottom off the pot, put in back in the hole and slit one side to slip the pot off. Roots get minimal disturbance this way unless I slit them a little which is rarely. Don't do what these TV people do unless truly root bound, which is unlikely, or unless you want to set the tree back a year in growth.
This way has given me nearly a 100% success rate as long as I water for the first couple years when it's hot or dry. New trees love water and the right amount of fertilizer.
Mostly I do spruce trees and hardwoods but you can also dig volunteer maple trees this way. In fact, the maple trees in our yard blew in as seeds from the neighbor's place and we put the seedlings in pots. Any bare root or small tree does well in pots. Plus, if you live in a windy or cold area, tress started from seedlings fare much better than larger transplants.
I also know how to graft your favorite apple trees onto mail order apple tree rootstock with a near 100% success rate as well. Maybe over the winter someone will start a thread and I'll join it. This tree stuff is easy if you take the lazy man's way out. :D
/ Planting Apple Trees #22
Great, thank you !! 9x9, sounds about the size of a gallon milk jug, wonder it that would work for pots?
/ Planting Apple Trees #23
Not sure if it would work for the beavers, but around here people use roofing tin formed into a tube around the trunk and wire-tied, to protect against porcupines. Leave plenty of room for growth so you don't have to expand it for a few years. It should reach 30" high off of the ground so they can't grab the top and climb over, and the tin is too slick for the buggers to get their claws into and climb. Porcupine is a brutal pest around here because they like to girdle the tree bark, and once they do that everything above the girdle is dead. I lost two cherry trees, a pear tree and a number of birch before I heard about that trick. Haven't gotten around to replacing those trees yet, but when I do they will all have some tin around the base.
/ Planting Apple Trees #24
Maybe. Have to try it but not sure I like the milk jug idea. Too tight and non-draining and bigger might be better anyway. There are a lot of used pots around and the 9x9 is a common size. we scrounge them here and there but you can also look at nursery or landscape auctions. You can buy a lot for a little. Make sure you have drain holes.
/ Planting Apple Trees #26
I use my small 12 inch auger to plant Apple Trees, but I drill three holes close to one another and then clean things out with a diggin' bar and a shovel. I've got clay in my area and I was advised not to leave the holes with "slick walls", so I score up the holes with my shovel. I mix in some good soil from an old garden to create a good mixture. All of this has worked great for my trees.
As far as protection, a small chicken wire covering around the trunk will keep the mice away - don't mulch right up around the trunk. I've also put a ring of 4foot high wire fencing and fasten the fence to the ground with two pieces of 3' rebar. You can get the fencing at Tractor Supply or Home Depot.
Good Luck!
/ Planting Apple Trees #28
Everybody's conditions will be different. Deer and gophers are what eat new trees here.
We put 'deer fence' (1/2" plastic mesh) around 1"x1" stakes that are slanted outward. This discourages deer from nibbling on new buds for the first few years.
Last year we planted 85 trees and immediately lost five to gophers. It's discouraging to water a week-old tree and it falls over because there is nothing left underground. We replanted these elsewhere and I think one made it. Beyond that the rest are coming along fine.
We use wire cages from the garden store ($5~10 each) under the occasional family fruit trees we plant, but not for the commercial apple orchard.
The backhoe does a great job of preping a planting site. In my case I'm always digging out a decades-old stump so I dig a cavity at least the size of a card table plus follow the old roots outward as needed. Then refill and pack down with the tractor tires, level, then dig a planting hole with the backhoe or just a shovel.
Here's my watering rig. An IBC Tote is a perfect fit on the little Harbor Freight 40x48 trailer. I had to strengthen the tongue, otherwise no problem pulling 2600 lbs on a trailer rated 1/3 of that. (But I wait until the trailer is near empty before going up/down slopes like this photo). Vacuum cleaner hose and plastic pipe make a lightweight watering wand, as shown.
Each tree has a levee around it that takes 15 gallons of water. The gophers are so prevalent that I often have to stop and plug a drain hole, rebuild a levee, or dig the fluffed dirt out of a basin, before filling it.
/ Planting Apple Trees #29
Do you have problems with apple replant disease?
http://www.tfrec.wsu.edu/pages/organic/Replant
/ Planting Apple Trees #31
Surprisingly, no. Even after abandoning the nasty stuff and going Certified Organic. (Maybe the century's worth of pesticides residue is still out there).
It is mostly fungal pathogens from the rotting roots of the old trees. It is not something a pesticide would do anything about. What root stock are your new trees on?
/ Planting Apple Trees #32
I should know the root stock but I don't. The orchard is operated by a neighbor together with his larger operation and he bought full-size traditional Gravenstein for the 2012 replacements. He and his crew do the major phases - discing, mass planting, annual pruning, harvest, etc. I dig out stumps, water new trees etc.
Here is a link to UC Davis school of ag publications describing local apple growing:
Within that list, download the pdfs titled:
coststudies.ucdavis.edu/files/94appsprk.pdf‎
coststudies.ucdavis.edu/files/94appdry.pdf‎
These studies describe in detail 'best practices' that several of my neighbors described to the researchers.
I try to dig out every trace of the old stump and roots, and make sure the earth that was nearest the stump isn't near the planting spot when I'm done digging. This seems to avoid fungal infection of the new trees.
/ Planting Apple Trees #33
Interesting. I am grafting from trees planted by ancestors in the 1970s and still hanging on. Some are Gravensteins. I am also grafting onto onto full size root stock that I grow from Russisn Antonovka seed
/ Planting Apple Trees #34
I planted 12 tree's 15 yrs ago and lost 8 to deer chewing them off. So I started using concrete reinforcing wire. This works well.
If you cut wire on edge's you can hook the wire in a hoop to the other side. In the last few years I have planted more trees and found that I no longer need to put large protection around them. (I think because there are a lot less deer). I plant semi dwarf trees at 20' apart.
/ Planting Apple Trees #35
I've lost 2 apple trees to the storm last year, which I planted 6 years ago. Take care from this point of view.
/ Planting Apple Trees #36
We have a small orchard. 15 old stock trees (gravenstein it appears) and a dozen new stock trees, a mix from cherry to new apple brands and some pears. I think we are going to put in another 4 trees and call it quits for the orchard. WAY too much maintenance.
This all said, when we went to buy our trees at the local nursery, I asked for normal apple trees, not dwarf or semi dwarf. Thought the sales people head would spin off. We can't get that, not sure it exists. Now I have some semi dwarf.. whatever...
Oh, as for digging we have clay soil and for most every planting I do I use my 12" post hole. Yeah, a 30 or 36 would be ideal but I have yet to loose a tree with the 12. Roots gotta move through that hard soil without my help....
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
New Holland T5 120 Tractor (A64047)
New Holland T5 120...
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
