Planer
/ Planer #21
Also us PLANER MEN can put sides on the boards to your liking ,such as v-match,shiplap,square edge etc etc.The machine i run goes up to 300 feet per minute [which is slow in todays modern mills],id be willing to bet we can plane it faster then you can unload it:D
ALAN
I so wish you were closer!
/ Planer #22
We dont do much custom planing since we have 8 large retail stores where i work and also do a very large quantity of wholesale ,whch is shipped across the country and CANADA.We can do almost any pattern available ,[including cabin logs and cabin siding]for we have the heads for about anything,and sometimes ill invent something:D
If you guys like planers the one i set up is a YATES american a-20.It has 6 knifes per cutter head and does all 4 sides in one pass and you can also do two profiles at the same times.So with 6 heads running at once ,8 sets of feedrolls and lumber flying threw it faster than can be piled manually ,you need to be well taught to keep all your body parts:p.After 25 years of shavings and sawdust in my blood i still have all mine:D
When you guys speak of jointers i think of something else.The definition of a jointer to me is a tool mounted on a track with a stone mounted in it to sharpen planer knifes while its running.Yes we dont have to stop to change knifes for a knick in the knifes,we "joint it" and keep right on chugging along.:)
If any one gets a chance to tour a mill do it.They are pretty awesome.If we happen to be doing dementional lumber ,and im not grading ,i enjoy cranking that old girl up and watching the 2 by 4s come out like bullets in a machine gun:D:DThe boys are glad they have an automatic stacking machine when thats going on:)
CANT TELL IM A MILL RAT CAN YOU?:D
ALAN
/ Planer #23
Blades are easy to change and about half price on ebay for brand new compared to Home Depot.
Eddie, my Delta 12 inch planer has disposable blades. Rather than buying new I found that they could be honed with a wet stone. It saves some money and works for me.
I've got about three or four sets that I use and then sharpen the lot at one time.:D
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63118)
2023 Top Air ATV...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
BOB TAIL KILL TANK (A63569)
BOB TAIL KILL TANK...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
HARDEE ADJUSTABLE TANK MOUNT (A63745)
HARDEE ADJUSTABLE...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
