Planer help needed
/ Planer help needed #1
Glenn9643
New Hebron, MS
MF 1455v 4wd, 1040FEL
My step-father had most of his timber blown down by Katrina, as well as everything in his area. He located and purchased a good bandsaw mill and a larger tractor/FEL a few months back and has been trying to salvage as much as he could for lumber.
Tonight he was seeking advise on a planer, but all I've got is a Dewalt portable that's not enough for what he needs. I'm a fan of Grizzly cabinet saws, but don't know anything about their planer products.
I don't really know but I would think a 20" would be the largest he would want and he might could get by with a little smaller. The main consideration is to find one that will stand up to continuous use that he can get parts/blades, etc. for. Single phase power is another requirement.
Any experience here with recommendations?
/ Planer help needed #2
First, I'd recomend he air dry it before he surfaces it.
Second, if it's a one-time thing, he may want to hire it out to someone who has the big equipment and who can pick it up, plane it, and return it for a fee when it's dry. This kind of heavy timber use is what kills lesser machines.
Remember, you need to joint the boards/timbers before you plane them, so you will need a jointer too.
Finally, since I don't know what kind of wood it is or how many board feet we're talking or how big the boards he is sawing out will be, I can't help much more than that.
Cliff
/ Planer help needed #3
I'd suggest he tries www.forestryforum.com. I got a raft of sound advice there when I was buying my mill and I'm sure it'll help with planer information. There's also a commercial section where they have used stuff from time to time, including planers.
/ Planer help needed #4
I have the Shop Fox 20" planer with a 5hp motor on it. I really like this planer. It is similar to the Grizzly which is a 3hp unit. The SF comes with a two year warranty, the Grizzly is one year. The shop Fox has a dealer network so you can look at it hands on, the Grizzly has to be ordered and shipped. I have some Grizzly machines that I am very pleased with and I am not knocking them. I plane mostly hardwoods and that 5hp has yet to bog down on a full width (20") board. Get the biggest motor available on whatever machine you decide on.
PS: I also got the quick change, disposable knife set up from Grizzly. This is a sweet no hassle system that eliminates the jigs and gages in knife changes.
Cliff,
He’s got lumber stacked all over his place drying. All the sheds are full and he’s had to start covering stacks with tin. It’ll be a while before any of it’s dry enough to plane, but he’s starting to look now for a machine. In his area there’s no place available that does custom planing. He’ll not be working toward fine woodworking lumber so I don’t think jointing will be necessary prior to planing. Thanks.
Inveresk,
Thanks for the link. A lot of good resources.
Dozernut,
Thanks for the info on the Shop Fox. I believe they’re marketed by the same people as Grizzly. Are the prices comparable, or do you know?
/ Planer help needed #6
They are a little higher in price than the Grizzly, but I think they are built a little heavier plus the two year warranty. I believe Grizzly is the parent company of Shop Fox, in fact I ordered my SF from Grizzly, as I live in a rural area and had no local dealers.
/ Planer help needed #7
If i were you id consider taking it to a place with a big planer[a mill] and get the custom planing done,the going rate use to be a hundred bucks per thousand ft not sure what it is now.You will get all 4 sides done at once,with the sides able to be a pattern,such as v match,or shiplap etc. Most folks want wood that fits togeather.The more knifes in the machine,the better the finish,the faster you can feed it. Id look for someone with at least a 6 knife Yates,or in your area Newmans are good big machines
Being a person who does this for a livin,ill tell you make sure the guy sawing it gets it reasonably sized to specs,and watch out for that bandsaw wave,not so much its hard to get out.keep the wood clean! If you do take it to a pro mill,and you do hit some dirt or rocks,they have jointers on the machines that take out the knicks,and also even up all the knifes.Better than livin with the lines in the boards,if used for finish stuff,or to keep changin blades in a home machine.
15 inch would probably be max width on most of these machines,remember even after dried wide boards shrink more than narrow.lumber should be sorted to width before bringing to the mill
ALAN
/ Planer help needed #8
He would be better off to cut it all on his mill. Then bring it to a mill to be planed and kiln dried. He could then store it or sell it.
/ Planer help needed #9
There are planers out there that can be run by the PTO from his tractor. We got some Amish people around here that do it with diesel engines. With a PTO driving it he could plane from pile to pile and could go with a 20 or 24 inch model. Sure would make a pile of chips in a hurry. Talk to Grizzly and see what they can come up with for a PTO unit. Then go on the foresty forum boards. Those guys on those boards are a wealth of imformation just waiting to share it with someone.
/ Planer help needed #10
Why does he have to join it?? If so get a 4 sided planer. bcs
/ Planer help needed #11
</font><font color="blue" class="small">( Why does he have to join it?? )</font>
Well, if you want a flat board, you joint one side, then plane the other. You can't remove bow, cup or twist any other way. A planer pushes the board flat on to the table and gives you even thickness (thus the name thickness planer). If the board goes in twisted, it will come out twisted, just with even thickness.
Cliff
/ Planer help needed #12
Try looking at the websites for Fine Woodworking magazine or American Woodworker. I know both of them have run reviews of planers in the past so you might be able to dig up some "professional" opinions of the options that are out there.
Fine Woodworking:
http://www.taunton.com/finewoodworking/index.asp
American Woodworker
http://www.rd.com/americanwoodworker/action.do?categoryId=7000&siteId=2222
I have a 12" Dewalt Planer that has worked very well for me during the construction of my house. I have also used Powermatic and Delta tools and their stuff is very good also. Try doing a search on Amazon.com under Tools & Hardware for planer and you will get a lot of results. Amazon lets buyers put in reviews so you can get some good feedback there. I think if it was me and I was in the same situation I would take a hard look at the Powermatic - 5HP, 230volt/1ph.
/ Planer help needed #13
</font><font color="blue" class="small">( . . . go on the foresty forum boards. Those guys on those boards are a wealth of imformation just waiting to share it with someone. )</font>
Deerlope,
Can you give me the website for the forestry boards?
Thanks,
Eddie
/ Planer help needed #17
Egon,
Thanks, there's allot of information on that site, looks like fun.
Eddie
/ Planer help needed #18
Hi Glenn,
I think you have some very good recomendations from some of my fellow woodworkers. Just by listening to you on the amount of lumber that needs to eventually be joined and planed, you are going to want a pretty substantial machine.
I presently use a 15" Grizzly that works fine for my occasional project. If I was using it more often and running large amounts of lumber through it I would have the carbide knives on it.
Another thing that I didnt hear anyone talk about is that, properly covered that lumber wont go bad, you just need to keep it dry and it will last forever.
As Cliff mentioned, you will also need a joiner to get the boards flat. I presently use a 8" Delta, that works quite well, but obviously your limited to 8" wide lumber. I would be glad to help with any other questions.
scotty
/ Planer help needed #19
I would be careful about covering it up until its planed/dryed,blue stain,or other fungi can set in.lumber needs to breath.ALAN
I believe he meant to keep it protected from direct sunlight and rainfall. If it's covered and has good air circulation those things won't be a problem.
As they cut they'll stack and cover. As they progress with the cutting what is stacked/covered will be drying. Eventually they'll get around to planing after the lumber has dried, and stack and cover it.
The amount of timber that's been blown down in the southeast states is hard to imagine. My step-dad is one that's going to try his best to not let anything just go to waste, and he's eighty years old (with a son-in-law helping him). Due to health issues with my wife, I can't be there. I started this thread in an effort to get information regarding machines to plane lumber, other than lunch-box portable planers that I've used. I appreciate all the responses.
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2015 Chevrolet...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
APPROX (9)PIECES OF 2'X11' CORRUGATED METAL SHEETS (A62131)
APPROX (9)PIECES...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
