PJ Trailers
/ PJ Trailers #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I am looking at thier 5" Channel Car Hauler (C5)
I am looking for feedback on the trailers.
I got a quote for a 18 foot by 83 inch wide trailer with brakes on both axels and 2 foot dovetail with ramps for $2695.00
I was lookng to get a landscape trailer same length and width with a split fold-up gate and dovetail and the rail around the bed and made by the same company PJ, for $3220.00.
I am torn bettwen the two trailers, Help me decide.
Car Hauler:
PJ Trailers - 5" Channel Carhauler (C5)
Landscape:
PJ Trailers - 83" Channel Utility (U8)
/ PJ Trailers #2
What are you doing with it? I can't use one with a rail around it for most of what I haul, some people love them.
/ PJ Trailers #3
I wouldn't buy a PJ trailer if I had too, especially if it was for daily use in a commercial application. The landscape contractor I worked for bought several because they were inexpensive, they didn't hold up well at all and the frame even broke on one of them. If it was for occasional light use they might be okay.
Brian
/ PJ Trailers #4
As Brian mentioned PJ is a ok brand but by no means the best.
If it were me I would get the car hauler. I hate gates and most car haulers have stake pockets so if you need to you can make a rail and sides.
That price on the C5 seems good to me but spring for a spare tire. Most do not come with them but it will be the best $200 you can spend. Also get a proper sized lug wrench and 6 ton bottle jack. I learned the hard way back when I broke my F-150's jack trying to jack up a loaded trailer. Once I did get it jacked up my truck wrench would not fit.
As for Powder Coat I do not like it. Give me plain old BLACK GLOSS PAINT and day of the week. PC if chipped gets rust starting under it and then it peels off. Tough to touch up. My trailer is painted and I keep a rattle can of Rustolem Gloss Black in the tool box. Touch it up after every couple of uses.
Chris
/ PJ Trailers #5
I've got a PJ dump trailer and it seems to be very well made. Well thought out, excellent welds. Heavy duty. Definitely made well enough to do what it's rated to do, and then some.
A different design than what you're looking for, but mine is excellent quality. The only one maybe better, that I have, is an old Zieman equipment hauler for my tractor.
It seems a lot of manufacturer's are cutting way down on the steel these days and it really pays to do the research. Look them over well and compare. I've noticed a huge difference, especially in enclosed trailers. They can look just the same on the outside and be WAY different underneath.
/ PJ Trailers #6
I have a PJ trailer and I really like it. It has the removable front/side rails. Powder coat paint is the way to go. It holds up a lot better in the weather. I don't see why you couldn't touch up powder coat with a spray can if needed. I didn't buy PJ because it was the cheapest trailer. I bought it because it is a very nice trailer. They are made in Mexico and some people don't like that.
/ PJ Trailers #7
I have had a PJ 83" channel utility trailer for four years now. I think they are excellent trailers, and I would recommend them. There was alot of steel in their channel series when compared to the competition I was seeing.
DiamondPilot had a good point about the gates though. If I were to replace mine it would not have the gate. I have thought longingly about replacing it with an 18' 9900 lb PJ equipment trailer.
/ PJ Trailers #8
For those that say the PJ is not a good trailer I would like to know what they consider good trailer within the same price range. So that specs can be compared.
/ PJ Trailers #9
I looked them over at the MN State Fair last fall and they looked pretty darn good to me. But I'm no expert... Looked solidly built to me.
/ PJ Trailers #10
Another vote against powder coat- I hate that stuff. Only trailer I ever had with it (SnowBear) was peeling sheets off in a couple of years in the weather.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Iranch IRGC40 (A60463)
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
