Pivot pin on tractor walking beam
   / Pivot pin on tractor walking beam
Just a hand held/pump gun. Not sure the rating.
Does the housing have relief plugs? They look like small pipe plugs where grease fittings could fit, but on opposite sides of the actual grease fittings.
Mine has the plugs and according to the manual, the plugs need to be removed, then you can grease the joint. Excess grease comes from those holes. Wipe away, re-install plugs and you're good to go.
Now with some hours of heavy loader work, I can usually get 3 pumps of grease in each without removing the plugs.
I’ll have to take a look. I can pump a little in now but it was because I installed an oring a touch larger. It still was snug on the pin, but not as tight. That’s all they had. I may get the proper one if I can find the metric size and reinstall. It probably didn’t need to come out. But nothing I could do could get grease in there and I wanted to check why. I realize it might of just been sealed real good and packed tight. I’m rolling around taking it easy so it probably didn’t need any grease.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
