Pivot bushing bad
/ Pivot bushing bad #1
Twistedgrip
New Holland TC55DA EHSS
Good afternoon. I have a TC55DA EHSS that has a worn pivot bushing boss on the front axle housing. Has anyone had any luck welding these and machining the weld back down?
Couple of questions… Is the axle housing cast iron or cast steel? I need to know some specs on the stub boss ie what is the proper OD?
I’m confident I can get this sorted out but will accept any advice.
Thanks
/ Pivot bushing bad #2
If the issue is wear, and not broken castings, it might be better to re-machine what is there and then turn up flange bushing that "fixes" the problem.
There are no issues with HAZ or filler rod compatibility that way.
And only a machinist is needed, not both a welder and machinist! ;-)
/ Pivot bushing bad
Welding it up shouldn’t be a problem other than preheat and cool down rates. Problem with machining what is there is the boss is hollow on the inside and to remove enough material to get back “round” I fear it may be too thin to support the load.
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
2000 Komatsu D61PX-12 (A64126)
2000 Komatsu...
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
LOT LOCATIONS (A59914)
